- Replies 26
- Views 13.1k
joecool911 5 posts
Mopar1973Man 4 posts
hex0rz 3 posts
Ilikeoldfords 3 posts
I asked this before...but after 6 months of 2 cycle oil use I've still got ticking going on. Sound comes out of both front wheel wells. No difference one side to the other. I try to listen to other 24 valve rigs out there and some have the clicking sound and others don't. I adjusted my valves, but should probably look at them again. Maybe one was way out and I adjusted at 20 rather than 10? Other than excessive lifter noise, could a bad injector cause the sound? Idle is smooth, but power and torque seems lower than I feel should be, but that's not backed up with any kind of inpherical evedence. Oil pressure good, fuel pressure optimum, fuel economy around 14 when towing a 4,000# work trailer. Does white smoke a bit on cold startup, but smooth. Wondering if that is more steam than smoke. Nothing has changed. Been this way ever sinc e I've owned it. I've put 30k miles on it. Wish I had one of you guys local to compare trucks with. With stock exhaust. I got on this subject again after watching the high idle cold start videos with white smoke coming out the tailpipe. Figure my first thing is to re-check my valve adjustment. I love this forum! Much more responsive and reliable knowledge than any other forum on any subject. Kudos to Michael! I'll send more money when I can. Money tight now as my hip is scheduled for replacement and I've been working at about half pace and therefore- half revenue. I am not only slow, but am limited on how long I work before pain becomes intolerable. I'm taking 12 asprin a day to maintain some level of comfort. At least my blood should be thin enough. Lol.
