- Replies 18
- Views 5.1k
CTcummins24V 8 posts
hex0rz 3 posts
Clunk 2 posts
mulcher812 2 posts
Just installed a genuine holset 60mm compressor wheel and housing on the WH1C, from GDS. I believe it was a 56/60/12 and now it's a 60/60/12. Only took it on a small victory ride but it seemed to pull better in lock up in the lower rpms and up high too. Already had a boost elbow and a 38 lb spring waste gate.
I was wondering if anyone has experience with hybrids and how efficient they are for around 400 horsepower. With my current mods: edge comp, 60 hp injectors I should have around 415 hp at the crank and I'm done increasing power. No sled pulls or track time, is the 60mm compressor too much for 12cm turbine housing?...no gauges yet
