- Replies 11
- Views 21.9k
kedlin88 6 posts
dripley 3 posts
Mopar1973Man 2 posts
Got some questions about swapping an ECM. I am having issues with my WTS light and no pump prime at key on or bump start. All grounds and fuse's have been checked.
Can a smarty reprogram the replacement ECM or does a dealer have to do it? Will any ECM work from a 1998.5-2002? I have heard the 01-02 wont work on a 1998-2000 because of the crank/cam sensor difference?
Dose it matter if the replacement ECM is from a automatic or manual transmission? Some say it will work, some say they wont program?
On the back of ECM's there are part numbers, serial numbers, and some other series of numbers that aren't labeled. Should I try to match a particular number on the ECM's?
Lastly, anything special that should be done when swapping the ECM's?
The local dealer can get a reman ECM for $729 plus 1/HR labor for reprogramming which is $110. Comes with 1yr 12,000 miles warranty. Reasonable?
Thanks,
Kyle
