- Replies 11
- Views 4.9k
Kotta390 3 posts
MnTom 2 posts
Mopar1973Man 1 post
flagmanruss 1 post
Well last night I installed my new steering box and let me tell you this...HOLY HELL did it make a HUGE difference. The steering went from about 40-50 degrees of play down to maybe 10 degrees of play. The tseering is SO much more responsive to turns now! I got a reman unit from Carquest Auto Parts and it is just amazing what the difference was from the stock unit. I want to give a very big thanks to MnTom for sending me the factory bolts to install the new box and they worked out excellent! I can't thank him enough for helping me out in this situation. The only thing that kinda sucked was removing and installing the pressure and return lines on the box itself. It was a tight area to work with and if anyone wants to know, they were both 18mm fittings. I swore up and down thy were standard but none of the bolts/fasteners were standard that I could see. Everything went back together fine and now I am one happy camper!
Just thought I would share and again Thanks MnTom for the help!
