No crank
Tested batteries and terminals and wont get a crank. 2000 stock dually, 5 speed.
  • Replies 3
  • Views 1.5k
Try jumping across the starter and see if it engages. If not I would start with the contacts in the starter could be bad.
It could also be the clutch switch in the cab.
Ya if you have a test light see if you are getting power down to starter. Could be fuse, relay, clutch switch, wiring in the steering column, starter.
