- Replies 8
- Views 3.7k
diesel4life 3 posts
oldbeek 2 posts
MnTom 1 post
volkswagon 1 post
I have browsed ever post on 2nd gear lock up. I am still confused! I didn't have the mod done when I recently had my trans overhauled because I wasn't sure what I could expect from the mod. Just read a post where the person said the truck would continue on into 3rd when in lockup. Will it do this if I have the selector in 2nd? I have a triple disc converter and a stock input shaft. I can't afford any surprise hard shifts when in lockup under a hard pull (13,000# load). I want to use 2nd lockup only to use it with selector in 2nd, then unlock before shifting to higher gear at the top of the grade. Will it do this? It would be most helpful if someone with the mod could explain EXACTLY how it shifts and is used. Thank You
