Battery Tray Bolts for 1999 Cummins 24V
- Replies 8
- Views 6.3k
kerley 3 posts
anoldbiker 2 posts
Mopar1973Man 1 post
mopartechnician 1 post
I am trying to remove the left [Drivers side] battery tray. I removed the visual nuts and bolts from the battery tray, it wont come out, so I went online for information and they speak of battery tray bolts that are attached from the bottom of the tray which I can not see or feel. My thoughts are to remove the rubber/plastic wheel cover shield on the fender to gain access to the battery tray bolts. The wheel cover is attached with several plastic clips which has to be removed for access. I need to remove the battery box to access the Cruise Control Server and hoses/wiring, Sorry for the long story but I want you to understand what I am doing. If there is an easier way to access the battery tray bolts please tell me. Also where can I buy the replacement shield clips.
