What would cause fuel gauge to read higher?
I can't figure out why all of a sudden my fuel guage would start reading higher than normal. It's a cross the range. Doesn't start coming down off full for a longer time. Reading about 1/4 tank and taking 32 gallons. I could understand a float becoming fuel logged and not reading as high as it used to. But all of a sudden it's reading higher. Battery still charging at a constant 14.4 volts. Same as always.
Is there a tank access mod through the bed in my future?
  • Replies 5
  • Views 2k
Ok then. Would appreciate the cut list to complete through the bed mod.
I forgot all about this material list. Sorry about this.
Joe, pm sent with my cell so we can meet. You'll see how to grind and fit so no welding or drilling on the frame. I should make kits for guys that want them.
Mike
