HELP! Electrical Issues with my Raptor 150 Pump. I''m Beat
- Replies 27
- Views 7.2k
mopartechnician 7 posts
gradymayhem 6 posts
Ilikeoldfords 5 posts
gassernomore 2 posts
Hey all, I've tried everything I can think of and I can't resolve this issue. My 2000 automatic won't start because the lift pump (raptor 150) won't turn on. I had only 3000 miles on it before it suddenly stopped working. So I checked my ASD relay and my fuel system relay, both were fine. So I unplugged the pump and bumped the starter and checked voltage with my multimeter. Got a healthy 12.3-12.7 volts.
So I figued the pump was bad and got a new one under warranty. When the new one came in, the same issue continued. I figured maybe there was some glitch and the ECM was telling the motor to defuel because the check engine light with p1693 came on when it stopped wanting to start. I suspect 1689 because I used to get that once in a while during hard starts.
So I unplugged my battery terminals and let everything reset. Plugged everything back in, issue is still there.
So what's up? Should I just hard wire the pump in to the battery? Is there another relay that could be bad? How do I go about testing the ground for the pump?
Oddly, the truck started without the pump plugged in and ran long enough for me to limp it 2 miles home, but turning it on and then plugging in the pump caused it to die immediately.
