47RE torque convertor locking and unlocking rapidly
- Replies 12
- Views 3.9k
Yankneck696 3 posts
MoparMello 3 posts
MnTom 2 posts
joecool911 2 posts
Just bought a 2001 2500 24v auto with 103,000. Everything was fine until one day my lock up was going in and out rapidly in drive and overdrive. Looked up a similar symptoms on the internet and a lot of people suggest moving a passenger side ground wire out from the wire loom that runs above the alternator and under the bracket. I moved the wire and reset my apps with the pedal procedure. I've only put 200 miles on so far but everything is back to BETTER than normal. Just curious if there's any other common problems associated with the haywire of the locking and unlocking of the torque convertor.
