1999 24v charging issues and more
- Replies 7
- Views 2.8k
Ilikeoldfords 2 posts
mopartechnician 2 posts
MnTom 1 post
Killer223 1 post
Hello,
I have a 1999 24v what developed several problems.
1. batteries get drained overnight
2. takes it several minutes to get it to charge 14 volts.
3. lift pump will not come on with key switch
4. lift pump will not come on with bump of starter.
Replaced alternator----same problem.
disconnected batteries for 1 hr.
Now lift pump will come on but it takes 5 to 7 seconds to come on after key is turned on.
Still takes several minutes for charging to get to 14 volts.
lift pump is not making enough pressure when running.
Batteries are less than 1 yr old and they are interstates.
lift pump is a fass that replaces the factory lift pump. its 2 yrs old.
I have a quadzilla programmer set to level 3. level 0 does the same thing, level 0 is factory setting.
quadzilla was installed 2 yrs ago. also new vp was installed 2 yrs ago.
I am guessing its the pcm, but any ideas would be helpful
thanks
