so a few days ago i went to start my truck after work (sat 10 hours) and when i started it, it took 3-4 cranks instead of normal, ran rough for the first few rotations, then bright blue smoke was coming out of the exhaust.
it has done this every time ive started it since.
any ideas whats causing it? i need this fixed asap, vacation trip coming up soon!
also on a side note, my fuel pressure gauge has a mind of its own. between 20 and 30 psi. bounces occasionally, spikes, doesnt alter whether i floor it or at idle
  • Replies 33
  • Views 5.7k
this thread was meant to be placed in the 24v powertrain section. sorry guys!
fyi, any ideas you have will be told to a shop, so please try to help me as cheaply as possible.
im still too nervous to work on the truck myself and also have no garage :(
I moved it here for you so hopefully you can get all the assistance you need. Have you scanned it for codes? Also, your fuel pressure gauge, is it an electronic sender type or is it mechanical?
Ok.
Any error codes present?
Is your grid heater working properly?
Is the fusible link burnt or blown for the grid heaters?
Is your IAT sensor reporting the proper temperature at start up?
fp gauge is electrical, isspro ev2, btw.
i have these codes
p1693
p0462
p0602
im not sure how to tell if the grid heaters are working properly or if the IAT is reading right. how can i do this?
wait to start goes off after a little bit and clicks. i think the grids are cycling
i have these codes
p1693
This is a companion code meaning there is/are other code(s) in either the ECM or PCM
p0462
This code is for the fuel guage Fuel Level Sensor Circuit Low Input possible causes:
- Faulty fuel level sensor
- Fuel level sensor harness is open or shorted
- Fuel level sensor circuit poor electrical connection
p0602
This code is for a faulty program not recognised by the ECM. Generally caused by a programmer and normally ignored.
My answers to your codes are in blue. For the grid heater, when you first turn the key on (while waiting for the :wts: light to go out) is the volt meter down around 10 volts? When it first starts does the volt meter go up to 12+ volts and drop down and go up and drop down...... You get the idea..? If so they are functioning, but if not, then it would make for a rough start and some white smoke when first started cold.
oh okay yea, the grids arent the problem then. they are working properly.
someone mentioned possible valve seat issue? im taking it to a very good shop monday, hopefully i dont get screwed.. i am 4 hours away from my shop since i recently moved, of course this is when i need tools
would injectors cause this? or valve seat? anything i can check quick with little to no tools that anyone can think of?
Have you tried to cycle the grids a couple of times before you start the truck? Mine is getting to wherer even today in 25* weather I needed to cycle the key twice to start mine.
Cycle mine only once in 14*F weather today and started right up.
As for valve seat issue do a compression test to verify the cylinder and head health.
I wonder if the cetane of the fuel was just too low? I'm starting to wonder if fuels were changed over to weather fuel soon enough this year. I know I'm not a big fan of it but you might try a measured dose of cetane booster and see if that helps. But if it does it could be fuel cetane related and it could be compression related too.
mine has always started with 1 cycle. doible cycling isnt the issue, cutting out power at 60-70, shakey like its sputtering. somethings sure going on
is it safe to run cetane booster with my 1oz/gal 2-stroke mix Michael?
i will tell the shop to do a compression test and maybe injectors if that doesnt work.
what was your thinking on the IAT sensor? maybe i could buy a scangauge from advanced auto
Now you are starting to give some good clues. You are having some fuel delivery issues. Have you put a mechanical pressure guage on the verify the fuel pressure?
i can still gain speed, but its not the same.
i dont have a mechanical pressure gauge unfortunately. ill get the shop to check
i can lug it and will not smoke at all. usually theres some black smoke if lugged.
at idle i hear a weird noise, almost a ping or buzzing
All that sounds to me like you are not getting the fuel you used to. When was the last time the fuel filter was changed? I wonder if the lift pump is failing or has failed. I also wonder if your VP is getting ready to give up the ghost on you.
lift pump was changed 3 months ago. filter about 4. ill change filter this weekend.
i thought blue smoke was oul related?
Ok, are you having to add oil when before you didn't?
i will check that tomorrow and get back with you!
thank you guys for taking the time to help me! will check oil level tomorrow and we can go from there. keep checking in on this if you get the time please!
checked oil level, it is actually higher than it was last time it was changed. and has a slight greenish color when wiped on a paper towell, but has had that coloration since i can remember.
what does the level being high indicate?
Sounds like you are 'making' oil. In other words there is fuel getting into your oil. Pull your valve cover and look for leaks. The only other place that might leak fuel is the shaft on your VP.
taking it to mechanic masters in paris, ky monday. they were recommended by thoroughbred diesel, apparently thats where they send all their work thats not sponsor work. ill tell them the symptoms and let you guys know what they find. just incase they try to screw me
