Hard start after sitting over night, losing prime maybe?
- Replies 4
- Views 6.4k
Dieselfuture 1 post
24Vdodge 1 post
Greenlee 1 post
Hawkez 1 post
Hi All,
have not been on the site for a while. To many other things in life going on. Had to go reset my password to get back on.
So I have a quick question for you all. In the last week my truck 1998.5 24V has been acting up. After it sits overnight, go out in the morning to cold start it, it will fire right up, run for 10-15 seconds and then die, like it ran out of fuel. Then it is a real bear to restart. It acts like it's out of fuel, or losing prime. It only does this the 1st cold start of the day, the rest of the time you shut it off and restart it throughout the day, it fires right off and runs great!!
My driveway is level or flat, no steep inclines around here.
My truck has a fuel boss system I put on it. It has been great and trouble free. I've had it on there now for over 70,000 miles without any problems, it still has the original belt on it I put on at the time of the install. It always has 15-16 lbs FP at idle and 19-21 ruining down the road. Other then the fuel boss my truck is stock, well except for the 4" exhaust and BHAF. Other then that it's stock.
This morning I checked over the fuel system. I found two fittings that are wet, like they are seeping a little fuel. I wonder if this is where my problems is? Maybe where the fittings are seeping a little fuel, after it sits over night is sucking a little air? Causing it to loose prime over night?
Thanks for any tips, and help.
Edited by 24Vdodge
