- Replies 44
- Views 9.2k
TFaoro 17 posts
rancherman 11 posts
Mopar1973Man 3 posts
jigdog 3 posts
I went snowmobiling the other day and now have popping going on inside my front end when in 4wd and there is pressure on the drivetrain. I believe it is the CAD as I have already jacked up both sides, checked all 5 U joints and turned the driveshaft (Pinion feels tight and driveshaft turns with ease). All U joints look good and have no slop in them. The transfer case has very little slop as well. The only thing left is the CAD. I think the diaphragm inside the actuator has gone bad because I can suck on the side that pulls the CAD over onto the disconnected side and it holds the vacuum. If I suck on the other line, it does not hold vacuum. Is there anything else I'm missing?
