Cutting out surging bucking
- Replies 11
- Views 25.1k
Dodgepwr 5 posts
dobienut 3 posts
Mopar1973Man 2 posts
dually 1 post
I have a 2001 cummins I've had this problem for some time now after I drive it for 30 min or so it starts to cut out at around 1800 rpms and above it will not hold a steady spot I just changed the vp44 it has not ever thrown a code ounce I have 18lbs pressure to the pump at all times the chip has been taken off and that don't make a diff I'm really lost on this one it's a 5 speed manual and ounce it starts doin it and I pull over and put it in neutral and try to hold rpm a like two grand it will go down to like 1400 and jump back up then down to like 1800 then up to like 2200 it's making me crazy thanks for any help... And thanks to mopar man for taking so much time to help out the av Joe
