Fuel pump change, idling at 2500rpm
- Replies 8
- Views 2.6k
CSM 3 posts
Mopar1973Man 2 posts
joecool911 1 post
AGPTurbo 1 post
I just changed out a factory lift pump on a 2001 Cummins to a FASS DDRP. Everything installed tighter, also added a sediment filter in line before the pump. Cycled pressure through and started the truck right now. It goes Immediately to 2500rpms and holds there. Good news is it is showing good pressure at that high rpm, but it is NOT coming down.
is there a reset that needs to be performed, or did something get bumped during install?
Vehicle is equiped with an Edge JWA tuner. No other mods that i can tell from sight.
Thanks!
