vp44 and hy35 questions
- Replies 18
- Views 4.8k
Mopar1973Man 5 posts
RubberDuck01 4 posts
TFaoro 4 posts
Frankstein 3 posts
Hi guys, I want to know if I can tap the hole in the hy35 housing where the metal hose goes for the wastegate. I want to put the elbow that come with the edge jwa for increase boost?? Does it work or I'm better with a j-hook to increase boost??
Second question. For my 2001 24v automatic, does this vp44 pump #BOSH 0470506005 ---- #CUMMINS 3676670 fit directly on my truck or I need to get another key for the shaft?? If its bolt-on right with no problems?? I found one near. guys want 500$ new and said its for 1998-1999. It's a close enterprise ...
Thank you
