- Replies 16
- Views 13k
Dodgepwr 5 posts
Alberta Bound 4 posts
Mopar1973Man 3 posts
gassernomore 3 posts
My truck died on the hiway today(2000 ram 2500 diesel, auto). I did the key trick and the code P1693 showed up along with the code P1682. I believe P1682 has to do with a voltage problem. Where do I start with this? Maybe an external voltage regulator is needed? Am I on the right track and why would the truck just shut off and still have enough juice to turn over at a normal rate? Any help or thoughts on this would be much appreciated.
