2001 2500/ AC quit?
My ac quite working. Clutch not engaging.  Checked for a code. None found. Checked continuity through hi pressure switch and clutch circuit. OK  Checked clutch physically with  external  12 volts. Clutch engaged. Any suggestions??  Where can I find a schematic of the ac circuit?
  • Replies 24
  • Views 14.3k
Never saw one on a 2nd gen but the one I added to my 2010 works awesome, last time I changed it had about 5 lbs of dirt in it and was filled level full with the pleats., literally dumped the dirt out of it when I pulled it out, will need to change it more than once a year I guess, thats a lot of dirt that was not on my dash or plugging up the heater core or evaporator. :wow:
