How hot are you?
Heck still getting mid 90s to 105°F. I get up in the morning at 6am and working by 7am. Like yesterday I got up and ran to McCall and installed injectors in just about 2.5 hours and was home by noon before it got really hot. The client was working local fire here in Donnelly ID. 2005 Dodge Ram 2500.
How hot are you?
Here we are seeing signs of a early winter and a deep winter. Must be those DemocRATS news media feeding you misinformation. Bees and wasp are building nest high above the ground and early. They are also out collecting pollen and resources early before the winter storms come. Animals are still high on the mountains currently because of the heat but soon they will be coming down as the storms come. I don't listen to NOAA or any government agency for weather information. I pay attention to animals and my surroundings. Just like today I had to go up the mountain pull a mink out of the neighbors water line. Then the neighbors are warning of a bear coming to their place and raiding the apple trees. Soon to be here raiding as well. Bears are starting to bulk up for winter so... Winter is going to be most likely long and snowy.
How hot are you?
We've been floating right about 95 to 105*F all summer make it tough to be working outside boiling sweat.
Thanks to the forum!
With +150 HP Injectors (popped at 320 bar) and Stock HX35W turbo I don't even watch the EGT's. Again the biggest thing that will affect EGT's is the final ratio, overly big turbos, and over advanced timing (Boxes like Edge Juice) which don't have any ability to adjust timing but only stack more timing on the existing stock ECM tune which is not correct for larger injectors. Even with what I'm running I've got a pretty good amount of retard to spool the turbo, which keep the smoke at bay. Then once spooled the timing is advanced. If your final ratio is too low (less than 3.55) then the truck will produce high EGT's and poor MPG's. Excessively low cruising RPM are not good they will keep the EGT's high. Like myself with the my setup... Watch the elevation, I'm running nearly flat and 55 MPH the EGT's are super low. Out on the flats of New Meadows, ID
Engine Article - Engine Oil Pan Gasket Replacement
Not really unless your wanting to do bearings on the connecting rods and main bearings. You'll end up removing the pickup tube anyways when you install the new gasket most of the pan gaskets have the oil pickup gasket in the corner and you can cut it free, to install it separately.
Traction Bars for short box 2wd
Still the ride will improve with softer tire pressures. Yeah I might run the pavement but I also run the dirt roads like yesterday when I ran all the way out to Warren, ID. We also made a trip over to Toller Ditch looking for Huckleberries which the season is nearly over now. Yeah if you run offroad then softer pressure do make for a much nicer ride. Over an hour travel on dirt roads. 2 hour trip from home to Warren ID.
Only if you base your tire pressure off your axle weight than just filling to 80 PSI. So like on my truck empty... 245/75 R16 rated for 3,042 pounds at 80 PSI as a single. Front Axle scale weight = 4,440 pounds Rear Axle scale weight = 2,860 pounds (4440 / 2) = 2220 / 3042 = 0.729 x 80 = 58.3 PSI Front Axle Pressure (2860 / 2) = 1430 / 3042 = 0.470 x 80 = 37.6 PSI Rear Axle Pressure Now if I'm hauling my RV (2000 Jayco Eagle) then I run 60 front and 60 rear pressure and it nearly a Cadillac Ride. Just for information value the 60 / 60 front and rear will hold 8,800 pound of vehicle weight. Even My RV I only run 60 PSI with max inflation of 80 PSI again load range E's. The RV is just about 8,100 pounds scaled. Just my tires 245/75 R16 (Load Rang E's) are rated for 3,042 pounds at 80 PSI so if I multiplied that 4 times, that is 12,168 pounds of vehicle weight my truck can haul but my GVWR is rated for 8,800 pounds. So there is no need for max inflation on any 2500 series truck.
thermostat help !!!
Oil pressure is near correct but there is a few small tweaks I've found. Like Volt Gauge if it reaches 12.00 it displays correctly. But as soon as it hits 11.99 Volts then the gauge drops to 8 volts and trips the check gauge light. Same with Coolant Temp if it passes 230*F it will swing to far end and trip the check gauge light. I've check my oil pressure against a mechanical gauge its correct. The only time it will skew is if the high idle is used then the oil pressure shows high when the coolant drop to 123*F but other than that it shows correct.
Ditch that ATF+4 and run the Mobil 50 SAE, or Valvoline 50 SAE trans fluid the noise in much less its actually 90w gear lube that is GL-4 rated synthetic. I'm running in my NV4500 for years now. I've also loaded a customers truck (2006 Dodge 3500) with G56 with the same fluid and the customer loves it over the ATF+4 and shifts are butter smooth.
With my setup the stock turbo is better than the HX35/40 Hybrid I ran previously. Turbo upgrades are typically done too soon. Then other problem is the most people run oversize tires and wheels and destroy the final ratio. Like myself after tires my final ratio is 3.69:1 being I've got 3.55 gears in front and rear and then running 245/75 R16 tires which are 30 inch tires and it produces that final ratio of 3.69:1 making torque production way better, better MPG's, cooler EGT's being I can run as low as 500*F at 65 MPH. Even towing I rare to pass 1,100*F even climbing to 7,000 plus elevation, in Bridgeport, CA. no problems.
Yes. You can't get the pan out because the pick up tube blocks passage of the pan. You have to lift the engine quite high to get enough room to slip the pan out. After figuring this all out it was super easy. Jack up the frame, jack stand the frame so the front axle hangs free. Pull the two bolts out the engine mount just jack up the engine by the dampener or use a cherry picker and lift at the engine ring. Lift as high as possible. Remove the pan slide it over to one side remove the pick up tube and drop it in the pan. The pan will slide out the back. In my case it fell out by itself.
Red Head steering gear boxes?
Because I found out that Blue Top produces some of the parts for Redhead. Not to mention its still a sagnaw box and not a retrofit. I've had a long discussion with Ryan at Blue Top and know several secrets. Kind of like I know that Vulcan Performance builds plumbing parts for AirDog. So go to the source and get the real deal.
I'm running about 500 HP to the rear tires I do have a bit of axle wrap, but not bad. Running a 5 speed which I enjoy way better than the G56 that is in Thor that I really don't like at all. 4th gear to get to 25 MPH. Anyways the spring pack if the you have the camper special like myself has a very thick base spring to prevent wrapping.
Welcome to the site. Sorry for the lag I've been super busy these days. Just to give you an idea about my setup. +150 HP DAP Injectors (7 x 0.010) popped at 320 bar. Stock HX35W Turbo NV4500 Transmission with Valair Dual Disc Clutch 4 inch Exhaust straight Piped Quadzilla Tuner I've high marked at 28 MPG easily and cross the entire state of Washington from Seattle to the Idaho Border near Lewiston, ID for just bit more than 1/4 tank of fuel for 299.5 miles. So if you wanna play the MPG game you got to follow me I'm a pro at squeezing every last bit of MPGs out of a engine.
I'm a Blue Top user myself.
thermostat help !!!
No. The mechanicals are just two lines in and out. No return.
thermostat help !!!
At 10 PSI the overflow will be closed, by 14 PSI the overflow is fully open. Still in all reduced volume because of the small port. This will aid with cooling and lubing the pump. Won't do anything for the lift pump and churning issues. There needs to be 3rd line back to the fuel tank to allow free flow of the used fuel being the volume of the lift pump requires a 1/2 inch return to the tank. Carter stock Airtex Raptor Mechanical pumps (belt driven). FASS smaller series All these have same issue because no 3rd return line. AirDog 100/150/165 FASS 100/150 These two pump do have a 3rd line to return to the tank.
thermostat help !!!
Doesn't matter. It's a restricted flow if you pull the banjo out and look at the port in the VP44 it small. No 150 GPH your only using 2.5 GPH at 55 MPH at 20 MPG in the VP44 injected. So the other 147.5 GPH is routed from the outlet of the Raptor back to the inlet, churning the fuel and creating cavitation. This is roughly speaking not counting limited VP44 return. Return hole size. Inlet size
Help With Engine Load
No PC should be used technically for tunes. Yeah you can download it but the file is unusable on a PC. Then you should be able to use a ISB cable to transfer to your mobile device. At least for my Android I just tap on the file it starts the import process.
Sad to say iPhone and iPad have the most issues with tune files importing or exporting. Androids no issues, import or exporting.
thermostat help !!!
Yes sir. No 3rd return line to the tank.
thermostat help !!!
Look at it this way I bought 3 stock fuel pumps for 250 a piece in 9 months (Carter campaign lift pumps from Cummins). I next bought the AirDog in 2006 for 600 dollars and never spent another penny. OE pump lasted 250k miles. Replace with a bad 3rd Gen AirDog and seals failed about 3k miles. AirDog upgraded me to the 4th Gen 165 GPH pump. No problems since.
Nope. Below 1200 RPMs the ECM is in control. Quadzilla is only monitoring the CANBus, till RPMs rise.
Swapped out some 50hp injectors for some 100's today
Well you have to consider the rotational mass, that will still pull the MPG down. For every 1 pound of rotational mass you get rid of that is equal to removing 8 pounds off the frame. So small and lighter tires provide better results over trying to keep oversized tires which adds to that rotational mass. Back several years I compared 235/85 R16 to a 265/75 R16 which are both 31 inch tires but ditching the width of the tire I was ditching the steel belt and was almost 25 pounds lighter on the 235's. Now I dropped to the 245/75 R16 which adds 10mm of steel belt back but being its a 30 inch tire I gained more torque to the ground. I could swap to 215/85 R16 which is still a 30 inch tire but it would a bit too skinny for off road use up here in the snow. 3.69 final ratio It will produce 2,000 RPM at 66 MPH. This is excellent being you dead middle of the torque curve and the engine isn't lugging. Anything below about 1,600 to 1,800 is going to be to low in RPMs and the timing will retarded to long so the MPG's a lower. I'm running 21 degrees at 2,000 RPM's and hitting 28 MPG. Consider looking at racing tires and how light they are. This is because the rational mass. Anyone racing wants the power to the ground. Wide offroad tires are not efficient at all. Way too heavy. Personal note. My last truck was a 1972 Dodge Power Wagon that I destroyed the front axle trying to do lift kits and big wide tires and started snapping wheel joints, bearings weren't lasting long, and it was nearly every month I was fixing the front axle from the tires I put on and traded the truck in for the Cummins. I never did any oversized tires or lifts and never had any of the issues everyone talks about. Ball joints last forever, tie rods lasted very long time, no death wobble ever.
thermostat help !!!
This was the big problem with the Raptors people learn later on about what they missed with buying a Raptor. Now they try to reinvent the pump and get a return line and external regulator. The only thing you'll miss is the air separation which is a straw that goes to the bottom of the filter so the air floats to the top and sent out on the return line. Now doing custom installs like the last one I did I love when I ditch the instructions and do it my own way it turns out much better. That white Dodge the owner was super impressed with the setup and how the lines all go inside the frame and protected from debris strikes. Yeah I'm going to build a filter cover when the truck comes back after my road trip to Pigeon Forge, TN.
