Low Boost After Boost Elbow Install
Oil residue. Look like bearing time.
Surging while driving
3.55 gears and 35 tires are going to be a problem being the final ratio is 3.21 to the ground. Optimal is 3.55 to 3.73 to the ground. Be ready for a fight with EGTs till you change the gears to 4.10 in both axles which would be 3.71 which work work much better. I'm running 245s on 3.55 which is 3.69 final and capable of 28.04 MPG.
all gauges die, after shut down truck briefly starts & runs, but then dies
Your heading in the right direction. I would check all the CANBus wiring for issues. If there is connection issue it could drop the data and see gauges zero out. I've got to ask the DOM (date of manufacture) of the truck?
Copper Extreme Duty Battery Terminals for Jeep Wrangler
You need military style terminals then just copper lug the cables. I just done a 2006 Dodge back this summer and turned out good.
I can say the sound of the turbo was off while spooling. After seeing the rub marks yup I knew the bearings are done in the turbo. This stems from my parking brake being broke. So I'm shutting down so I can lock it down in gear. I'm pretty sure I've got a coked up shaft in the turbo.
@Krlspokane12 gotta ask what axle gears are running?
Dirt to snow or snow to dirt.
Yeah full track side by side or ATVs are really common out here. Not motorcycles with tracks. Ive seen a few passing on the highway but never send one running in the snow.
Nope. Maybe full track set up for ATV Honda Rancher... This is not mine... But wishing maybe... Addon: these are more than what I paid for the entire machine new... Ekkkk! https://atvtracksystems.com/product/honda-420-trx-foreman-rancher-rear-rigid-axle-2007-2013/
I wish. Truthfully when I get past some the stuff I'm doing I could hit the snowmobile rental shop in McCall ID and see if I can work a deal like I did 14 years ago and bought a Arctic CAT Panther Deluxe only paid $800 for it had a crack in the windscreen, I might do that again buy a nice one maybe next year?
but still its
Neat but out of my class of getting be an old fart.
HX35/40W Turbo bearing failure
Who built it?
Naw, too much issues for controlling. @Me78569he's already built a controller and done the entire turbo on his old 2nd Gen.
That excessive low end timing. That is about the only thing that causes the bucking issue in the low RPM's.
I must run in the wrong circles I've never really seen anything like that.
Yup sad to say the turbo I was running start sounding different on my last trip to McCall for parts and really low in boost pressure like 21 PSI. So this morning I pulled the truck in and start just looking and figured I would do just check the shaft play. Well that moves in and out just a few thousandth and the compressor wheel made contact with the housing I know the bearings are done. Thank Gawd that I kept my old stock HX35W turbo and just installed it back on. Back to making a solid 35 PSI of boost. Truthfully I would love to upgrade turbos but I know I'm going to need a new exhaust brake and install a PacBrake Inline on the 4 inch pipe. Then I could upgrade to a bigger turbo with better flow. Part that sucks I'll most likely have to tweak my tune a bit for a new turbo.
Cigarette lighter power intermittent
Different vehicle but my 99 Mini Van has two power points in the vehicle and both don't work well at all. The front one was a actual cigarette lighter. I normally plug in the Bluetooth/FM transmitter. Nothing happens, now with a light touch and barely any pressure turn the accessory slow counter clockwise and PRESTO it lights up and works. I know you should have to hang your jaw just right while doing a hand stand to plug in a 12V accessory to make it work. Tell you the truth I'm working my way away from cigarette lighter accessories typically you have the popping out on there own, bad connection, poor quality and burn up because the circuit has 20A fuse.
Grab a live data tool and monitor the TPS (APPS signal) and engine load. I wanna see if the something else is push the fueling command or is it just a poor quality APPS sensor. Unplug the Quadzilla main plug for a temporary moment and the turn the key on (not running) and measure the wire tap voltage be sure it same as the battery voltage. This will ensure the tap is good connection and that the VP44 is showing fuel solenoid voltage on the wire tap. Its working if battery voltage is at the wire tap. Another odd one that happen to me is verify the Quadzilla ground is solid I had my truck buck and do weird things when that bolt loosen up for the Quadzilla ground. AC noise does all kind of weird things. Like my 2002 Dodge (Beast) on the cruise control would randomly speed up and slow down. This is the AC noise from the alternator as the electrical demand went up with the heater blower, big headlights, etc the problem got worse. After doing the W-T ground wire mod the noise was reduced to a mere 11mV AC were about 50 mV AC most people start having random issues because the AC noise pollutes the hall effect sensors like speed sensors on the axles, speeds sensors on the transmission (hence the 3rd & 4th gear lock and unlock issue), this can even pollute the crank sensor signal so the cruise control will surge upwards past the set point and down below the set point because of AC noise pollution. The ground wire mod most the alternator charge lead to the passenger battery and the main grounds for the ECM and VP44 to the block and possible a secondary ground from the driver battery if done like my article. Takes about 2 hours to do the mod and I've done dozens of them and all worked perfectly. Now I've had a few issues with high load accessories like winch popping circuit breakers and fuses for the alternator but that not W-T Mod's fault its a defective accessory drawing to hard on the system.
Winter weather - What do you see where your at?
I've seen a few storms like that where massive snow flakes are falling and add up into feet very quickly. Pretty to watch from the safety of home but I sure don't wanna be driving in that.
Midna's build
Hate to say the more I work on the 4th gens the more I wanna keep my older trucks. Even Thor being a 3rd Gen its a OK truck but seriously it is more expensive to maintain and keep up. Now my older Beast is way easier to maintain compared to a 3rd gen. Now the last job doing a clutch and rear main seal on a 4th gen took 3 days of pure fighting. I typically do a clutch job in half a day on 2nd Gen.
Idle at 750 rpm-normal?
Normal park/neutral idle speed is 800 RPM +/- 5 RPM. If your idle is high means the ECT Semsor is actually reading lower temperature than it should. If it idling low typically the injectors are wore out. Most injectors are about 100k to 150k miles. This should be regardless of loads. When the APPS triggers idle mode the APPS value is dropped and the Cummins idle software is used. It's set for 800 RPMs you should be able to have everything on and sit at 800 RPM. If your live data shows ZERO engine load the injectors are wore out. ECM can no longer cut fuel to hit target idle speed.
I can handle that. I'll be out on my ATV plowing driveways.
Dreaded P0216 code, help/advice
- Dreaded P0216 code, help/advice
One small problem. That higher internal pressure is used to fill the pistons in the pump. There is no springs on the pistons to return them to outward but fuel pressure. The return flow is the un-used fuel that is returned to the tank. So that higher internal pressure is not seen at the return port. Being the return is routed directly to the distributor head on the other port. One in to the pistons and the other out leaving what is bypassed. The port towards the delivery valves is the return port and the port towards the shaft is the supply from the vane pump internally. Then the input fuel is also got little screens in the ports to protect the pump from debris. Pistons are laid out on the distributor head as you can see the fuel pressure is needed to push the pistons out to reload for full volume. The cam ring and shoes/rollers will push the fuel up to pressure all 3 pistons at once. As for the return routing... You can see the raised hump in the body routing to the return port from the distributor head to the forward port being the supply port is a open hole to the void below the PSG which is remove. This chamber is used for cooling the PSG since the PSG is heat sinked to the fuel.- Reve X Distance plus
Premium diesel is nothing more than high cetane diesel. Just to tear this statement apart some more... higher cetane is lower energy content of course just means you need to buy more fuel to travel the same distance of course fuel company will talk this up as a bonus. Better lubricity that's laughable being that all US fuel is ~520 HFRR which is sub-standard for lubricity which <460 HFRR which Bosch recommends for would optimal, Detergents another laughable statement injector cleaners don't even work in high concentrations. Actually it would help to keep everything cleaner with double filters at 3um... Chemical cleaners don't work... As ASTM grade scale shows high cetane the lower the BTU's... Dark green is summer fuel and light green is the winterized or what they call premium diesel. Just can't change that function higher the cetane value the lower the BTU's per gallon. Just for info at about 120k BTUs/Gallon is gasoline (high octane).Just look at the right side of the graph for the cst value that is the viscosity of the fuel in centistokes and higher the cetane the thinner the fuel at 100*F. Just for reference distilled water is a centistoke value of 1.0038, then 10w engine oil is 1,295 centistokes max. The other odd value is weight the more energy content the heavier the fuel is. Cennex Diesel Fuel (USA) Dark Green - 43 cetane, 133,000 BTU's per gallon, 3.2 Centistokes viscosity, +14*F pour point. Light Green - 53 cetane 126,000 BTU's per gallon, 1.8 Centistokes viscosity, -25*F pour point. Then again... Go back to this post in this thread... - Dreaded P0216 code, help/advice
