Retired Staff
  1. Double-check any of the suction side lines. Remember, these lines don't typically leak outwards. Being a vacuum allows it to lose its prime. Do you have metal JIC fittings or plastic quick-lock fittings? On those types of fittings, if you suspect a fitting to be leaking air, you can wipe a bit of grease on the smooth bore and leave it a bit thick. This typically fixes an air leak temporarily. Metal fittings you might want to double check the mating faces and make sure there is no damage. These must be smooth both sides! Any bad faces you'll end up replacing both fittings.
  2. I'll be heading into my 3rd Radiator now. I'm at 500k miles, and the tank gasket on the driver side is leaking. I cut the radiator cap vent disk off, and now the radiator does not hold any pressure, but I've been this way for over 1 year,r even with a 200℉ thermostat, and still have a leaking radiator still. This winter, I'm hoping to be able to replace that radiator.
  3. Wow. Just crazy to have a bad processor.
  4. Mopar1973Man posted a blog entry in Site News
    Some of you might think we are not around. Truth is, we are still working on cleaning up the shop mudslide disaster. Currently, we are down on vehicles, being that Beast just lost a starter, Thor had a random injector failure right at the time of the mudslide. Most of my tools and shop stuff are still buried in the yard. @Tweety Bird is trying to fill my shoes on the website by handling administrative duties. I'm working with the locals here to attempt to get use of a small track hoe and hoping for the return of the skid steer. Shop is still just a mess as we keep sorting materials to dispose of the debris while hunting for tools, parts, or any belongings. We are trying to plan for winter coming which includes getting firewood. Remember, both of my chainsaws are gone in the mudslide. Then I attempted to get both trucks running without a full set of tools and had to drive to friends' places to borrow tools for what I was missing. Currently, both trucks need work to get ready for winter. The crazy part is that I have to find help for the heavy-duty stuff because my cancer / ostomy is preventing me from doing most of this work...lifting restrictions...hernia risk...still building up my strength. Just another note, as for access to the website @Tweety Bird and I am sharing a laptop right now. Her laptop screen got damaged. My main computer finally gave up and the video card isn't rendering the screen correctly. That machine was built a long time ago. To top it off...our cloud server that controls the network here, is giving us backup, and storage and video recording of the security cameras just died too. I'm working on solutions to all these issues.
  5. Ok. I get your wanting to learn why it won't work. Don't make any mods that cannot be returned back from. Like milling the intake off.
  6. Be careful about this design. I still don't suggest this path. I don't think there is many gains to that whole intake system unless you are WOT all the time. I'm still assuming this is a daily driver street truck and not a strict race track truck, correct? Being a highway truck is going to be partial throttle most time. So boost is going to be low majority of the time. EGT can be controlled by timing. If you're looking for cooler temperatures, then you'll be milling the intake off to remove the coolant passage in the bottom. (1/2" pipe plug near the IAT sensor) Which is weird, being I've changed to a 200℉ thermostat from a 6.7L and am using custom timing and able to keep EGTs in check. At least in my design heat is my friend giving me better ignition quality but not over 140℉ intake temp ever even towing. Problem I see is the turbo is going to be hotter nearly 400℉ output temperature heading to the intake without a intercooler to cool the air before entering the engine. This link should help you figure out temperatures. Just https://www.stealth316.com/2-turbotemp.htm IC Efficiency as a zero if your removing the intercooler. IC Efficiency as about 85 percent value forthe stock cooler.
