awk02
  1. ha just found TSB 02-001-01 . mopar makes a lowering kit for 1994-2001 2500 and 3500.you have to remove auxiliary spring and spacer if your truck has code xzb which mine does , or camper special.anyone know why it would not work on 02? did not think they changed axles till 03 ???
  2. what do you guys think? insted of raising front susp. why not lower rear?for the guys running stock tires. i have been looking at leveling kit . carli,kore, lorenz.prices range 400.00 plus. and that is just springs and shocks.to center axle you still have to get new track bar. kit also increases angle of stock control arms.i do not want to alter oe steering geometry.anyone know whare to get rear axle lowering blocks and ubolts? thanks
  3. Thank you for information.
  4. Ha Guys I am looking for a set of chrome acorn lug nuts for my 02 2500 4x4. I know the thread is 9/16x18 .Are they bulge,xl bulge,or xxl bulge :confused:? thanks
  5. Hello I have electric on my 02.I did a lot of research in the design of my system.You could buy the flex-a-light 262 twin fan rated @ I believ 5500CFM.If you read application information the 262 system is not rated for loades over I think 18000lbs and it cost around 600$$$. Aftermarket should increas OE performance not reduce it IMO.My system uses 1-18" Ford Lincoln Mark VIII 2 spd. electric fan about 45.00 W/O shipping e-bay 1-16" Ford Taurus electric 2spd. " " " 35.00 " " " 2-fan control kits from dc control at sales@dccontrol.com around 80.00 each 2-fuse block 4-8 gauge w/ MIDI 60amp fuse 13.00 for both e-bay misc. wire and connectors 20.00 18" mounts on passenger side,16" mounts on drivers side. So for around 330$$ I have a varyable system that has a capacity around 7000CFM. Note: this is not a direct fit you will have to cut and rework the shrouds on both fans.You also have to build custom mount for winshield washer tank, took me about 1/2 hour once i figured how I was going to do it.You will have to relocate radiator reseve tank.Hope this helps. Tony
  6. Thank you!
  7. Setup does look good!! Where did you get filter and outerware cover? What filter # ? How much$$$ ?
  8. what company did you buy it from and how much?
  9. Thank you both.That was it.Why in the word would some enginer put a housing like that around a fuse were there is no other?Just to drive me nuts i guess.
  10. Ok guys I was tinkering the other day and I dead shorted a fuse:mad:.The real problem is I cant figure what fuse it is.:o The fuse controls under hood light,interior dome lights,cargo light and radio.Any help appreciated!!:confused:
  11. 90 to 110 ok . is that @ intake of motor or @ your BHAF? I would like to find a oil or water temp gauge that goes down to 90 deg. and tap int my intake air horn. what im thinking is building a box around my air filter.one side would be open to fender for summer use and open to motor for winter use. but on outside of box on motor side mount an 12" x 10" x 3/4" oil cooler,used as heat exchanger.tie into heater core supply lines.should still have enough water flow to oe heater core to heat cab properly. will check with guys at work about BTU output ofheat exchanger.any idea of CFM draw for 24valve @ say 2000 RPM?
  12. well since it is the cold weather season.does anyone have any info for a base line intake air temp to increase winter time fuel economy? my truck gets its best mpg from 55 to 75 deg. with low humidity. we put cold air kits on why not reverse for winter use and temper intake air?
  13. helloi have decided to go with a/d100 on my truck.do you still have pics of your install? i would like to keep my fuel heater as you did.i now have taped banjo bolt @vp44 for fuel psi gauge.can i keep this or does it have to change?how did you hook up psi gauge? thanks for all your help. tony
  14. helloI got a return e-mail today from Steven Opocensky ,the designer of the MITUSA.He stated sales stopped because they are so back ordered.Will not start sales again till begining of next year.
