Everything posted by capj
OPTI-LUBE Summer Blend
The above is not a trick question. I am totally satisfied with Wally World Super Tech 2 cycle outboard in the blue gallon jug. This is simply a question based on economics. IF the Opti-Lube will do the same or better job than the 2 cycle it would be much cheaper to use. But, will it do the job?? The "TEST" results says it will.... what do you guys say ? :thumbsup Thanks in advance...... :thumbsup chuck
Have any of you guys tried the Opti-Lube Summer Blend ? It is ranked # 4 in "The Test". I have been using 2-cycle exclusively for many, many, many miles now. :thumbsup [Thanks Mike & Dorkweed] But I got to studying the chart again and it finally dawned on my 'old' mind that the Opti-Lube Summer Blend would actually be cheaper to use and actually showed better results than the 2 cycle. I do realize the two cycle was tested at a 200:1 ratio, while I use a 128:1 ratio. The Opti-Lube at a 3000:1 ratio would be much cheeper than the 2 cycle at a 128:1 ratio.. What do you guys think ? Any down side to using it instead of 2 cycle?? Please be honest, you ain't gonna hurt my feelings......... LOL
Altenator question ????
Bingo boys............. it was the brushes. Thank's for all the good info.............. :thumbsup
Speedometer question ??
Thank's Mike........ it hasn't done it any more...... :confused: .........but when /if it does, you have given me something to "work" with........... :thumbsup Thank's for the link to the error codes too .......... :thumbsup :thumbsup :D
Does the speedometer in a 1993 Gen 1 w/ manual trans have a cable or a "sensor". Every now and then [ twice in the last two weeks ] my speedometer quits working for a short time.... a mile or so ....... and then it just starts working again. Any Ideas ?????
Stickers!!!
I think you have a winner Mike !!! :thumbsup I like the "small change up" you made in the second one too ............ :cheers
Price of fuel where you live ?????
Yeah, we topped out back in the summer at $4.699. ` I am with you "dorkweed" ....... unleaded regular is finally back higher than diesel here also. :thumbsup
How much is diesel where you live ??? Here in Orange Beach, Alabama for the last two weeks it has been $3.959 at WalMart. What about where you are.?????
Here is a poll of fuel additives
Amen ................... :thumbsup A BIG thanks to both of you.............. :smart
Thank's guys. Sorry for the late reply but I have ben real busy at work and also limited computer access.I will go out this afternoon and check out the things you suggest. Since I last posted it did it once for about an hour ???? But has been working fine ever since. :confused: I will check out the things ya'll have suggested though and see what I find. :thumbsup Mike, I had it bench tested a while back and it check out fine.Later,Chuck
Here is a question that I hope someone has an answer to. I have a 1993 and this has happened three times now. The altenator stops charging according to the volt meter gauge..... [and yes I have verified that it is not a bad Volt Gauge with a handheld.] The altenator when removed checks out good, nothing wrong with it. I only removed it once and had it checked. So, I just charged the battery when it began to get low....... I was just driving around town at the time anyway. This lasted about two weeks and then it just started charging again. This has happened two more times for a couple of days and then it starts charging normal again. Has not happened in a couple of months come to think of it. Anyway...... what could be the cause of this???? Any help is appreciated. :thumbsup
