97turbo
Everything posted by 97turbo
  1. Found a bad wire in the back of the truck , spliced in a new one. Issue fixed.
  2. Headlight switch is anywhere from 60 to 80 bucks where I live. I know it needs replaced cause when I turn the headlights on they don't always come on unless I jiggle the switch some. I just hope it's plug-and-play and I don't have to splice a bunch of wires.
  3. So it could be the headlight switch itself ?
  4. ^^^ will chech the socket better tomorrow , then I guess start tracing wires...
  5. Checked all the plugs, they look good.
  6. Replaced the trailer plug today ... Didn't solve the problem.
  7. I thought of that, but if that's the case would the turn and brake lights still work on that side and only the parking light not function ?
  8. Already tried new bulbs.... That didn't fix the issue. I also swapped the bulb from the passanger side which works fine, no luck either way.
  9. 97 2500 CTD- I've got a rear parking light out on the driver side, turn signal and brake light are fine, All other park lights come on as normal. I know my headlight switch is worn some because if I pull the switch out to turn on the headlights some times I have to jiggle it to get the headlights to come on. Could a worn out headlight switch cause that one park light not to come on ?
  10. Trying to wire up a new plug for the trailer. The one that goes in the bumper. Can I get help with the wiring diagram ?
  11. I run a 30 inch single row (30SR) amber light bar from Rigid. It is awesome.
  12. It was a piece of the peddle assembly in the cab. Can't tell you exactly as I didn't change it. If you search here there a couple of very good write ups on repairing the assembely.
  13. Got it fixed by local shop. $30
  14. How long would it take to change the assembly ? Mine is broke.
  15. Good luck !
  16. This is mine, I think it's 263#s. I put in a 2.5 inch leveling kit.[ATTACH]5976[/ATTACH]
  17. Anyone have any problems running the BHAF without an Outerwares ? I'm concerned about rain/snow. Mainly rain right now, we get some bad storms with high winds here.
  18. I used a CSF radiator I ordered online, worked great, good price and they are all aluminum . Just a thought. That was on a 95 Cherokee , I also used their radiators in my TJ.
  19. Genos came with the double lip seal.
