BRI7070
Everything posted by BRI7070
  1. I think I needs to get an he351ve and the arduino controller. I will have to make the best of the smarty for now. I looked into the Quadzilla website and there are quite a few options. What would be your recommendations?
  2. Me78569, I have about 8,500 lbs 5th wheel that right now gets pretty toasty towing up hill. The area that I like to camp in has about a 2.5 mile run up a 6% grade. I always seem to be fighting EGT vs trans temp. The Smarty has the ability to custom tune, but I have not played with it and I use SW5 for towing and SW1 for street. What I would like, If possible, is to be able to install the TST PM3 (I like the ability of the PM3 to pull out fuel to keep EGT below a user set temp) stacked with the Smarty and figure out how to tune it and be able to tow my 5th wheel and have reasonable temps and smoke control. I also like the exhaust brake function of the VE. If I am unable to custom tune the Smarty then I would just run the PM3. I would also like to be able to set everything to kill and play at the drag strip. If I have to put a hp level I guess I would like to have 400-450 useable rwhp. Is there someplace where can find out the differances between the 341, 351, 451, 551 turbos? Thanks for the help!
  3. Ok, with this controller having the ability to control other VE turbos, what are the choices? I looked at Holset website and did not find anything helpful. I did come across this site http://www.turbomaster.info/eng/catalogs/holset.php?serie=HE It is a start but does not have the info that I am looking for. Also what would be the next step up? What HP could it support? My setup is 2001 2500 4X4, Auto(DTT), 90HP DFI injectors, Smarty S03, and sitting on the bench is a TST PM3 Comp. I am in need of a turbo upgrade as I smoked my PDR-HX35. So before I install the PM3 a new turbo will be needed and I would rather not get something that would just cover what I have as I would like to go bigger on the injector. Especially if the VE can make the low rpm smoke minimal. What are your thoughts? Thanks
  4. Wow that is a lot of reading, mostly not understanding it. Looking at the LBB 2.0 Standalone and I wonder if this would control other Holset VGT turbos?
  5. Hello everyone, I hope someone here can help me out. I have a 94 Ram 2500 2x4 NV4500 that I what to swap transmissions with my 01 Ram 2500. So I am looking for the pinouts for the 94 and a 96,97 or early 98. The 94 pcm will give me the Pin outs for a 12 valve and the 47rh and the 96,97, early 98 will give me the pinouts for a 12 valve with the 47re. I want to do this swap because I prefer to tow with a manual and the 94 is in the process of having the body from a 78 Ramcharger put on it and I prefer to race with an auto. Any inputs? Thanks Brian
  6. hmmmm, Rheostat on the IAT? Could you expand on this? I am also looking to increase the economy of my truck, so this might be something I would like to do. Also Thank You for the Site. Great informatation
