Bobalos
Everything posted by Bobalos
  1. BTW, I wanted to say thanks to everyone for all of the help & assistance. This was a very frustrating deal & it was compounded by multiple issues. So....... THANKS!!! Now onto the heater core, Dash & all the fun that is going to come with that. I need to search & see if there is a "how to install a heater core in 30 minutes or less" instructional. LOL. Bob
  2. The first company I went to was https://carcomputerexchange.com/. I talked with Brian (their "tech support guy") on numerous occasions. I was very underwhelmed. NO technical help whatsoever & could not even tell me for certain what things they did or components they changed. Even after I explicitly called him & told him I this is what I wanted, BEFORE they even received it. They had 2 chances @ it & could not get it right. The second company.......... I dont know, and I dont know that Bruce would tell you. Seems weird that they would go through the time & expense to add it to the motor, Harness & software to not do anything with it. I supposed if it was used in some other application & it was simpler just to just leave it there VS removing it, that kind of makes sense, however being as these motors are explicitly made for Dodge vehicles with Dodge specific ECM's & tuneups........... just strange to me. thanks again folks. Bob
  3. Update (hopefully the last for a while.........) : a local shop (Steven Bruce, at Diesel System Services. blacksmokin.com), looked @ the truck & could not find anything wrong with it (other than what I found). He put his "test ECM" into the truck & it fired up & ran correctly. WTS light worked properly, Lift pump operated properly & Communications worked properly. He has a source for ECM's that he said is the company that remanufactures the ECM's for the big 3 & for a lot of the heavy equipment folks. He ordered me an ECM & had it shipped 2nd day air to Kalipornia (they are in the Easter Time Zone). Steve was kind enough to allow me to drive the truck for 4 days with his test ECM in it until the new one came in........ installed the new ECM, everything worked fine for 3 days ........... until................ Im completely loaded up & ready to to head out to the desert. it would crank but not start. He came out to my house (Thursday night, WAY after hours) & did a bunch of tests & we were able to get it running, however were not sure why. the last thing we were messing with was the Cam Pos Sensor. However......... what was strange to me was that with the Cam Pos Sensor unplugged the truck would start & run just fine & would not turn on the CEL until the truck had been running for 13 or 15 seconds. I was not comfortable taking everything & everyone out to the desert if we did not "fix" anything, so I told him I would drop it off @ his shop on Friday morning (assuming it would start & run). I went down to Cummins Friday morning & bought both the Crank & Cam position sensors. On the way to his shop with the truck it started Bucking & trying to die (the CEL came on), when I took my foot off of the gas pedal. when I got to his shop he scanned it & it came back with the Crank Pos Sensor DTC. THAT seems consistent with "some" of the issues I had been having with the truck. while he was under the hood he swapped both of them & then did a bunch of diagnostics to make sure that everything was happy. I picked up the truck on Sunday after we got back from Church & paid him for his time on Thursday evening & Friday. So, some things that came out of this......... Steve showed me how to start the truck w/o the key being on & 2 relays removed from the PDC to test to ensure that the Injection pump works properly. I dont understand what the Cam position sensor does if the truck will start & run fine w/o it even being plugged in....................... Now I get to fight with the first ECM company & see if they will refund my money for the service they did not provide me (twice), however I have to see if they screwed up my original ECM so badly that the second company will or will not take it as a core........ having multiple issues REALLY is a PITA..... thanks again folks for all of the help during this. time to replace the heater core and dash & hopefully the old girl is ready for another 100K to 150K before she needs more work. Im sure the trans will need frictions before then, but that is OK with me. Bob
  4. good news is that it appears that the Comm Bus wires look to be in good shape & there are no shorts to ground or opens or anything. I pinned it out between the ECM, PCM & ALDL & it all looks good. The bad news is that its still giving me that DTC. I will make some calls tomorrow & see if I cant find someone that can get me a good ECM. If anyone has any other things they think I should look into, Im open to it......... thanks Bob
  5. Well........ now Im getting a P1694 code. Im going to double check the PCM connectors just to be sure, and start looking for another ECM. Bob
  6. In my case that would not be of any help. Im in California, & it has to retain all of the OEM stuff (with some exceptions). Believe it or not I have to get my truck "smogged" every other year (started 4 or 5 years ago). They dont do a sniffer test, just visual inspection & connect to the ALDL to make sure that its talking & there are no DTC's stored. I saw briefly last night that someone has the 2002 (ish?) ECM's working on the 98/99 trucks. I have not looked into it @ all, but will sometime this week. not sure if there is any benefit for me........... Bob
  7. Mopar1973Man (I think your name is Mike, but dont remember exactly.......). I seem to recall in one of your other posts you mentioned that you dont have your grid heaters plugged in most of the time. How do you get around not getting codes? or do you get them & just ignore them??? I was just playing with mine & found that when I unplugged the relays I got a P0380, Po382 & P1291, which I think are all grid heater related. My OTC will not connect to the truck, but my $5 China Freight one will both get the codes & clear them. go figure.............. I started the truck up w/o the grid heater relays plugged in & the AC noise went to 12-16 mVAC (slowing moving around) & the DC was 14.11 & rock solid. I found that the Hot side on the forward relay was a VERY bad connection. it looks like it was hit or something & the connection was opened up enough to make it sloppy on the post on the relay. I cleaned all 4 connections up & tightened up that one connector & wouldn't you know it, it seems pretty happy now. I read both the AC noise & DC voltage & it seems MUCH better. in fact its more stable than when I had the Grid relays disconnected. Im getting 12 to 13 mVAC & 14.1 VDC VERY solid........... the WTS light is still inconsistent, but I was doing a bunch of starts & stops & setting DTC's & clearing them & whatnot, so Im going to give it an hour & try it again & see if its happy or if its just screwing with me again........... LOL. Im hesitant to call this thing fixed, but.......... it sure does seem a lot more happy....... Bob
  8. There is a Alt/Start company down the road from me that I used to use all the time when I was in college & the old guy that worked there was very good & would help just about anyone out. I will swing by with the Alt & see if they can bench test it. its been 20 years, who knows if they are even owned by the same guy. Im still unsure where to go for the ECM. I guess I can try Cummins on Monday, there is a local Cummins place here. I wonder where they get them rebuilt....... thanks Bob
  9. Any suggestions.on where to go? I'm not impressed with this company. The AC noise is fine as long as the grid heaters are.not on.... I will unplug them to test.
  10. everything worked correctly for a bunch of times, & then it crapped out again & its doing the same thing it was doing when I sent it back the last time. it seems to me that what is really broken is the EEPROM. what can cause that? the folks @ the rebuild company are useless. all they know is "I put it in the simulator & its broken" & "I put it into the simulator & its working". the only reason I mentioned the Grid heater is because it is creating a LOT of AC noise & dragging down the Alt a bunch more than I think it should be. (EA Grid heater ohms out @ 0.3 Ohms to ground. I dont know if that is good or bad, but it sure seems like that would draw 40 Amps EA, which seems like a bunch......). the voltage dragging down when the heater comes on could have nothing to do with the grid heater itself, but that the alternator is crapping out (or crapped out). I have not put one on the truck, EVER. 18 years & 200K....... Could the Alternator be causing the ECM to crap out? How about wiring? pinning out the entire harness is probably not gonna be a practical idea, but I could pin out some circuits if I had some idea of where to start. I dont want to buy another ECM & have it blow up too, but it sure does look like its bad........ something must be causing it. I cant tell if the communication issue is a red herring or is trying to tell me something. I tried to talk with it with both of my scan tools even before I started the truck & it would not talk.............. thanks again folks. Bob
  11. I know its only been a few hours, but anyone have any suggestions??? I have got to get this thing running properly again. Im 1/2 tempted to get a new alternator for it & Maybe new relays and grid heater. I dont know which came first the chicken or the egg. and........ is the ECM broken again??? thanks folks Bob
  12. I was not sure if I communicated the issue correctly so I went to make another video to show you what it was doing. to make a long story short, I started the truck probably 20 times & took it for a couple of short rides around the block & everything appeared to be working correctly (with the exception of the comm issue & the grid heaters cycling on & off & dragging the alternator down with it). I went for a walk with my neighbor for about an hour & just got back & read your post. So....... I figured I would do another video of what its doing in the truck & its now doing EXACTLY the same thing it was doing before I sent it back to the ECM company for the second time. It was NOT doing this before I sent it to them, It was simply having issues with the lift pump (as well as the intermittent comm issue) To make it clear right after I installed the ECM & started it a bunch of times. the WTS light was working exactly how I thought it should: ~ Turn on the key & it would turn on the lift pump (you can hear the gauge in the video below going bsssst, when the pump kicks on), ~ It would turn on the WTS light, then it would go out & the truck was ready. ~ Hit the ignition & it would fire right up & everything was fine, except it sounded like the AC compressor was cycling & dragging the idle down a bit. the Meter test followed that & it showed it was the Grid heaters causing the idle to drop/etc. Sorry about the language, Im SOOOOOOOOOO over this ECM BS....... Does anyone have any suggestions for a competent ECM place???? Bob
  13. update to this: last week I went through EVERY ground I could find in the engine compartment & cleaned them & made sure that the terminals were in good shape & there was no corrosion (there was none). I sent the ECM back to the re-manufacturer & sent them a list of the things that it was doing before I sent it back & what its doing now that I got it back. They checked it & thought the memory was bad. they flashed it again & thought something was bad again. they replaced the memory chip and all of the circuitry associated with the WTS light They reflashed it again & sent it back to me. I just installed it & the WTS light is acting normal again..... Yea while the truck was running it sounded like the AC was kicking on & off (I could hear the idle changing. I double checked & it was off & the compressor was not cycling. I put a meter on it to see what was going on & noticed that the AC noise was going from 10 mV to 1xx mV/200 mV & the DC Voltage was dipping as well. I reached down & put my hand on one of the Grid heater relays & it was cycling off & on. Yes its a little chilly here this morning (68*) and the truck has not run in a week, so the motor is stone cold. but.......... its San Diego........ it does not really get cold here..... Here is a quick video of the meter while this is happening. So, my questions: Is this a problem? Do the grid heaters go bad? Do the grid heater relays go bad? BTW, before I started the truck I tried to connect to the truck with my OTC Genisys & it would not talk @ all. I guess that will be the next thing to screw with....... something is up.
  14. I figured I would post a quick update. I called the ECM company & talked with their "tech support" guy & came away from the conversation MUCH less confident than when I called them the first time. He gave me a lot of "we always do, we 100% test, the techs bench test every system, etc, etc)". then when I asked if he had a report about what was done & more importantly what was not done, he said that he did not have such a thing. then the "always do"; turned into "when necessary". needless to say, I sent it back & told him that I would call him on Monday (tomorrow) & I wanted a detailed report on what was & was not tested. What was & was not found & what was & was not replaced. thanks for all of the help folks. Bob
  15. thanks, I will call them today & see what they have to say. the guy I talked with initially seemed pretty knowledgeable. thanks folks. Bob
  16. one thing that is still confusing to me is this, My OTC has what appear to be 3 scan modes (Cummins, OBDII & JTEC). Which one talks over which bus' & to which computers? If I take the test procedure I performed last night explicitly the ECM is "bad". would you agree with that & this is where I need to start? I had planned on contacting the folks that "re-manufactured" it & ask them exactly what they found was wrong & what they did to fix it. I have a feeling though............ that Im not going to get answers that satisfy me.
  17. I performed the DTC P1689: No com between ECM & Inj Pump procedure & it all passed all of the tests. the strange thing......... the first thing I did was to hook up my OTC Genisys scanner & it connected right up & allowed me to do everything I wanted it to do............ . I hate it when things "fix themselves". In my experience things dont just fix themselves. FWIW, this is the order of what I did: Scanned: P1694 Cleared code Cycled power, scanned: no codes Cycled power, scanned: no codes Cycled power, CEL ON. scanned: P1694 Performed P1694 test, everything was perfect. continuity tests: <1 Ohm, Power tests: 12.5V (Brand new batteries) Insulation tests: Infinite (NOTE: Wait To Start light is still inconsistent. sometimes it comes on as soon as the key is on & the dash lights come on & sometimes it waits for all of the lights to go out & then the WTS light comes on........ ) Turned on Ign: CEL On with OTC, there are 3 tests I can run that takes 3 different dongles on the cable: Engine: Cummins ("no codes present") Engine: OBD II ("no codes present") Engine: JTEC ("P1689 code present") Cleared P1689 Started truck: No CEL Started truck: No CEL Started truck: No CEL Started truck: No CEL it was >8:00PM so I figured I would go in & work on it the next day. The Scanner connected & worked perfectly every time I tried to talk with it....... Came into work this morning............ no CEL, truck ran perfectly......... I will check everything again when I get home tonight......... Im frustrated with this thing..... I know there is no clear issue to work on, but I feel that there is still something going on. If anyone has any more suggestions, I would appreciate it. thanks folks. Bob
  18. The truck seems to be running fine, so Im guessing that its the same P0230 code that I was getting before, but I wont know that until I get the ECM to start talking to the scan tool. thanks for the information, I will dig into it this evening when I get home. Any thoughts about writing up something in detail about communications & what is transmitted over what buses & what talks to what in what manner? I read the article you wrote about the different baud rates & priorities of what is transmitted, & Im assuming that is over the CCD back & forth between modules, but did not want to make an assumption............... thanks again Bob
  19. To start I have a 99, 2500, Auto, 2x4, 211,000, Lift pump in tank with Relay, 275 HP Bosch Injectors. I am the second owner & got the truck in 2001, IIRC it has 15,000 on it. To make a long story short, I just finished doing a bunch of things I have been putting off for too long now. Recently replaced (in order of installation): Vacuum pump (http://www.fixinrams.com/) PS Pump (https://www.genosgarage.com/) & Hoses (https://ormebrothers.com/). Brand new Bosch 275 HP Injectors (Had Edge Jammer Stage 1's & wanted to see the difference) ECM from https://carcomputerexchange.com/ (Lift pump was not turning on reliably & WTS light was acting all wonky) Fuel Filter housing for 00-02 Cummins https://www.genosgarage.com/product/dodge-ram-cummins-replacement-fuel-filter-cannister-gg-fc98599/360 I was trying to troubleshoot the lift pump driver issue in ECM & Manged to crack the 99 Housing, so $180 later here I am.... VP44 from https://www.bluechipdiesel.com/ (This is the second VP44 I have put onto the truck, the first very early in life, due to dead Lift pump) So here is the deal. As I mentioned Ive owned this truck pretty much its entire life & have put just about every mile on it. I had the vacuum pump, PS pump & injectors put into it by a local Dodge shop, because I did not have the time to take care of it. no issues/worries with that. off & on for the last year or so I was having issues with the ECM turning the lift pump on. I dug into it a bit & called the folks @ Blue Chip & Doug suggested that I just run the lift pump off of the Wiper circuit (as its hot during "run", but not "start"). while that worked fine (the truck would start & run every time), once of the side effects was that I was getting a P0230 code. I called Blue Chip back & he said that is because I did not have a load on the ECM (because the lift pump was disconnected) & that I should just "stick a fan on it to blow across the Inj pump" so that the ECM would see the load. I didn't like that idea, so I wired another relay on that output (the exact same relay that I am using for the lift pump) & much to my surprise that did not resolve the issue. I did a bit of research & called 6 or 7 ECM sources & found that car computer exchange seemed to be knowledgeable about the Cummins specific issues & had a good answer to each of my questions (Im a Manufacturing Engineer for a company that produces devices that measure air pollution). They were waiting on cores & said if I return mine I would get it quicker than if I waited to order one & then send my core back later. So I did that. I replaced the ECM & fuel filter housing @ one time & rewired the Lift pump back to the ECM where it should be. every few years I check all of my grounds to make sure that there is no corrosion (like we get any weather in San Diego, right...............) & that everything looks ok. I purged all of the air out & fired up the truck & it fired up after a little cranking. HOWEVER......... the CEL came back on again. I hooked up the scan tool, cleared it & fired it back up again. no more CEL. Yes I did something stupid............. I did not read the code(s) I just cleared it/them. I replaced the Injection pump & when I went to fire it up, I found the batteries were on their way out (slow cranking & no fire). they were 5 years old so I replaced them. Hit the key with the new batteries & it cranked over great & fired right up. HOWEVER the CEL is back on again. I broke out the $10 China Freight scanner & it came back with "there are no codes" (yes the CEL is on) This is not the first time this has happened. So I broke out the OTC Genisys, & the freaken thing wont talk with the stupid truck. This is not the first time this has happened over the last 8 or 9 years. Ive had this issue off & on for a while. Ive not cared because the truck has worked fine & not had any CEL's so why would I care (paying for that now..............). Here is where it gets weird. If I use the HF scanner & force it to clear the CEL it will do it. if I ask the OTC to clear the CEL, it will not. neither of which will "get data from the truck". the CEL comes back on just about every time I try to start the truck. Ive cleared & started it 20 or 25 times since I replaced the Inj pump & most of the time the CEL comes back on. I have tried a few things. like checking connections & Grounds & other such things to figure it out, clear the CEL & fired it up & it comes back on........ MORE.................... So........ the questions....... I have a factory manual & have dug into the schematics & see that there appear to be 2 Comm buses. once is the CCD & the other is the SCI. I have read a bunch of stuff on this site as well other places, but am kind of confused about how this works & what does what. as much as anything Im trying to learn with these questions, not to just fix my problem, so bear with me. I get that the CCD talks between the ECM, Timer, Dash, PCM, etc to transfer information from one place to the next. it is also present on the ALDL so I would assume that a "scanner" can talk on the buss as well to get data out. It appears that the ECM & PCM are connected to the ALDL on pins 6, 7 & 14. Its interesting to me that there is a single transmit line shared between both computers, but they each have separate receive lines. SO............... When I hook up my scan tool cheap *** scan tool what is it talking with? the ECM? through the SCI lines or the CCD? When Im using my OTC & turning on & off the AC Clutch, Trans Solenoids, lift pump, etc. what buss is it using? When there is a code that the trans is not working correctly, where is that coming from? is the scan tool talking with the ECM via the SCI & its getting the codes from the PCM through the CCD? How the heck does this work......... Shoot........... I didn't want everything in one HUGE post............ So, Specifically to this problem. How do I go about troubleshooting my communication issue? I took the OTC & plugged it into my wifes Mercury & it allows me to see everything & do everything, its working correctly. I have had issues with the Truck talking to scanners before, but Ive also had it work just fine & allow me to turn on the trans stuff & to datalog ECM & PCM stuff & watch the APPS voltage go up & down & everything you would think it should be able to do. so I know that it has worked before. IMO, I need to get the scanner working before I can figure out why the CEL is on. I suppose I could assume that its the same P0230 code, but I dont want to assume anything........... thanks folks. Bob
  20. I have not found anything that does a decent job of boost fooling for my truck. I have tried 3 or 4 of the dongles that plug into the MAP sensor & they all give unreliable performance. "Comp boost fools", who is comp? thanks again Bob
  21. with increased boost or with the stock 20Lbs? seems like much more fuel & EGT's would go up a bunch. I tow ~10K up over the mounting into the desert during the winter & dont want to have to deal with EGT issues. (Im in San Diego, CA. so its not like I have real winter to deal with, but its a pretty good tow over the mountain). DAP = Diesel Auto Power? DFI = ???? thanks Bob
  22. I did not mean the pour into the tank stuff, I mean removed, sonic cleaned, rebuilt, assembled, flowed. Kind of thing. I was considering getting a set of RV injectors, Maybe its time to start looking that direction. thanks Bob
  23. My truck (99, 2x4, auto, quad cab), is fixing to spin 200K & it occurred to me that I have not done any maintenance on the injectors & I was wondering if there is a cleaning/maintenance interval on the injectors. Is there such a thing as injector Maintenance like there is for Gasser injectors (cleaning, flowing, etc)? Yea I know they are different critters, but they do have similarities. thanks Bob
