catnhat
Everything posted by catnhat
  1. With the raptor it does have a adjustment screw for the pressure have you tried turning it up. The pressure gauge sounds like the same way I put mine in and never has problems with it.not 100% sure but I thought I read somewhere on here that someone makes a metal cap
  2. When I put the rear sensor I went for a short drive and the light never turned off
  3. So it won't just plug in and fix my abs light
  4. Change the speed sensor didn't help i got a new abs box from the junk yard same year as mine is there anything that is different or should they be the same
  5. I do have the lights on but my speedometer is still working just fine
  6. Ok so I should only have the sensor on the rear pumpkin and one the photo part I don't have the attach file option
  7. Mine doesn't look that that though it's just a little black Blox on the side
  8. Yup right next to both towers nothing is plugged into either of them if I could figure the picture thing out it would help. Did all trucks come with them
  9. Ok I think I found it right by the abs module and there is nothing in that one also
  10. That's the one nothing is plugged in they're where is it on the driver side
  11. Still cant figure out pictires but I was looks at your post and in one of the pictures the one with the air box off there is a plug and in yours it looks like that is where the abs plugs into and in my truck they're is nothing plugged in to it
  12. Did they all come with front sensor I took a picture not sure how to post it
  13. That's what I thought and I just can't find it
  14. My abs and brake light are one I am thinking a have a front sensor out. I wanted to make sure there wasn't a wire broken and I can't for the life of me even find them and I just missing them or does the wheel have to come off
  15. I saw that and they give spares thanks
  16. Otherwise they had Johnson I think it was for a little cheaper
  17. Since I have you all I was going to redo my vacuum pump. So I called the dealer and they wanted 70 bucks seems a little ridiculous for 4 small chunks of rubber is there anywhere else to get it from
  18. Well I cleared the codes and when I was looking this over I found a battery cable wasn't tight. After I tighten it up,the Truck seems to be running great and the code hasn't come back. I just hope that was it thanks for all the help
  19. Good little info to know just happy I found it before any harm was done
  20. My plan was to drive with each one and see which one I like more the shitty thing is I have 3 timing boxes now
  21. Thanks for the help I ended up take the pp out the superchip that I had has some better features
  22. Is the some kind of chart that says with turners can go it each other
  23. I can't seem to find if they are fueling or timming
  24. Like I said I was looking under the hood today and found a Diablo sport power puck and I don't know anything about them.will it play well with my superchip
