1999 Dodge lift pump
@WesHawkins, the 10 amp draw sounds like a healthy lift pump. You are probably right regarding an overlooked fuse holder condition. - John
AC from AC?
@Andyba20, I think you are being led astray here. There are many, many things that affect compressor cycle time. Here are a few dynamic variables that occur every day and have a major affect on compressor cycle time in a fully charged and properly functioning air conditioning system: * blower fan speed * recirc or outside air * ambient temperature * ambient dewpoint * engine rpm * air flow across the condenser * sun load So, without naming some parameters, no one can say what is normal for compressor cycling frequency. On our 2nd generation trucks, compressor cycling is controlled by a low pressure switch downstream of the evaporator core. When refrigerant pressure falls to around 30 psi, the compressor will cycle off. 30 psi equates to about 30°F. This means that condensation from air passing through the evaporator core can collect and freeze onto the core which would impede air flow into the cabin if the refrigerant pressure remains at 30 psi or lower for a long period of time. When the cooling demand is low (75°F ambient air, 45° dewpoint, blower fan on low bringing in outside air, truck parked in the shade), the compressor will cycle frequently - I am not going say how frequently. When the cooling demand is high (85° ambient air, 70° dewpoint, blower fan on medium bringing in outside air, truck parked in the sun), the compressor will probably run continuously. It isn't "locked on", it simply cannot reach a low enough suction pressure to cycle off. Now, with all of that said, if your truck's cooling demand was high and it was hot outside and your compressor is cycling frequently, then it is likely there is a low charge of refrigerant in the system. Recovering the refrigerant and weighing what goes back in is the most accurate method for charging the AC system. - John
Bent Rear Sway Bar
I fully agree with you there. Not even close to being heavy duty. - John
Personally, I have never found a multi-meter with a DC amp clamp connector to be reliable for direct current measurements. I think you are having the same issue with your meter. From a couple of other sources, 12 amps was the response for current draw for stock lift pumps. Years ago my truck had a factory in-tank lift pump with relay installed under warranty by a Dealer. The power to the relay was supplied by an added 20 amp fuse. If the lift pump truly only drew .5 to 1.5 amps, then a 5 amp fuse would be more than adequate. There is a positive displacement vane pump (called the feed pump) inside the VP44 injection pump. It is this pump that drew the fuel into the VP44 without the lift pump operating. As long as there is not a blockage from the fuel tank, the engine will run. The purpose of the lift pump is only to supply a positive pressure at the inlet of the VP44. - John
Not sure how you are testing for current draw, but those numbers are way low. I don't think they are real. The current draw should be more like 8-12 amps. I would suspect that you are getting a severe voltage drop across the fuse connections while the pump is running, which will generate lots of heat, even from a perfectly good lift pump. Since the fuse holder was already damaged from a previous situation, the fuse holder needs to be replaced. I would jumper the existing fuse holder with an in-line 20 amp fuse and re-test the lift pump. If the fuse holder still gets hot, then you have a lift pump that is beginning to seize. If the fuse holder stays cool, then you have found the problem. - John
Bent Rear Sway Bar
Your hitch receiver should be a Class 4 - 1000 lb / 10,000 lb with weight distribution, but only 500 lb / 5,000 lb weight carrying. Horrible safety factor. Is the label still on your hitch receiver? - John
Dodge 2500 OEM Hitch Receiver Failure
Yup, looks to be in good condition. - John
No buss with new ecm
There is a ground wiring modification in the Articles section on this site that is called the W-T ground wiring mod. This mod primarily reroutes the alternator output wire to the passenger side battery and addresses some poor electrical grounds that could affect the PCM and the ECM. In particular, there is a factory ground splice that isn't even crimped near the front left side of the engine. One of the wires in the splice is a ground for the ECM. I am not saying that this will fix your problem, but it is an important step for protecting computers and electronic devices, such as the PCM and the ECM. Double check wiring connectors for the PCM and ECM and any associated connectors for pins that may have been pushed back inside the connector and are not making contact. Hopefully, you will hear back from your ECM repair guy. - John
I guess that relates to the geographical differences of where our trucks have been. I didn't have to deal with any rust - no broken tabs, the bolts just came right out. Just curious, did you see any evidence of separation at the rear of the OEM hitch receiver (like in the above photo)? I realize you didn't use it much, so it was probably okay. - John
There are many things that can cause an engine crank, but no start condition. What made you focus on the ECM? What are the symptoms? Did the problem come on suddenly? Any codes set? Any information you can provide about how the truck was running prior to the problem as well as some history on the truck would be helpful. - John
@Max Tune, I don't know any source of information regarding the strength of the truck frame where the hitch receiver mounts. I tried to get that information from Etrailer.com, but I just got a canned response. Personally, I think the frame is far stronger than the hitch receiver. I saw no signs of stress whatsoever on the frame after removing the OEM hitch receiver and inspecting the frame. The new Curt hitch receiver is six inches longer consequently using more of frame's strength. I seriously doubt that I will ever have any hitch issues again. However, I will perform better inspections in the future. - John
Bent Rear Sway Bar
Yes bumper pull, well actually truck hitch receiver pull. You may not have read my post regarding my OEM hitch receiver failure. I have replaced the hitch receiver with a Curt Class V hitch receiver which allows for a much better safety margin. OEM hitch receiver: Curt hitch receiver: - John
Bent Rear Sway Bar
You may recall that during the late '90''s and early 2000's, trucks were being sold with the "Camper Special Package" option. This included auxiliary rear leaf springs and a rear anti-sway bar for carrying slide-in truck bed campers. Otherwise, trucks did not come with those options, even if they had the trailer tow package. - John
Bent Rear Sway Bar
I have removed my OEM rear anti-sway bar. I no longer have my truck camper (high center of gravity load), so the rear anti-sway bar is not needed. Get a little better ride with the truck empty on certain roads. The truck tows very well without the bars. Just arrived home from a round trip to Boise picking up two pallets of pavers. GCW coming home at 18,000 lbs. - John
dash lights and gauges powering up with key off
For sure, I think you need to call in an exorcist. Until then, don't park the truck by your house. If that doesn't work, then try this. There are wires that break or chafe from flexing over time in the tilt wheel area. You can remove the lower cover and inspect these wires. I have had to repair some of these wires over the years. - John
A/c compressor help
I would not assume anything. Did you inspect the first compressor that was suspect for failure? Was there any metal debris present at the outlet port? It would probably be best to remove and inspect this compressor for damage before deciding your next step. Earlier I asked if the engine cooling fan was turning (assuming it is an engine fan that pulls air across the condenser). This answer is important. If there is no air flowing across the condenser, then compressor output pressure can rise rapidly to a destructive level and will / may activate the the pressure relief valve. Without gauges (especially a high pressure gauge) you are only guessing at what is going on in the system when the compressor is running. I would definitely install quality gauges on both the low and high pressure ports before doing any further testing. - John
A/c compressor help
What were the high and low pressure readings when the failure occurred the first time? the second time? What was the ambient temperature for each time? I am assuming there is an engine clutch fan. Was it turning? From information you have posted, it seems like the system pressure is excessive on the high side. - John
Serpentine Drive Belt - What is the best
I always use my old belt as the backup because I know it works. On rare occasions a new belt can fail or come off right away, OR it might even be the wrong belt. So, if one waits for the old belt to fail and then replaces it with the new "backup" belt and Murphy's Law strikes - well, that's what Murphy's Law does, here you will be sitting alongside the road..., - John
About a month ago I experienced a hitch receiver failure on my 2002 2500 4WD Long Bed truck equipped with a Cummins engine and a manual 6 spd transmission. Although I have inspected the hitch many times over the years, I overlooked a critical area during those inspections. The hitch-to-frame fasteners (four on each side) were always tight. However, a couple of inches away from the fasteners (at the first 90 bend in the hitch receiver flange) is where the separation occurred. It started on the left rear side of the hitch receiver (a long time ago) and continued forward until the hitch receiver dropped away from the truck frame as I was pulling off to the side the road. Only the right side of the hitch receiver stayed connected to the frame while I finished pulling off to the side of the road. There are several things that attributed to this hitch receiver failure - most of which is on me. Closer detailed hitch inspections and using the hitch within its rated capacity would have gone a long way toward this event never happening. The OEM hitch receiver is rated as follows (a sticker is located on the hitch receiver). These are maximum ratings: With Weight Distribution …..... 10,000 lbs trailer weight, 1,000 lbs tongue weight Weight Carrying …………………. 5,000 lbs trailer weight, 500 lbs tongue weight I never paid attention to the Weight Carrying maximum - a serious oversight. The first few years of the truck’s life I occasionally hauled a 6,000 lb equipment trailer and a 10,000 lb dump trailer without the use of a weight distribution hitch. Since 2013, I have always used a weight distribution hitch. The gross combined weight when the hitch receiver failure occurred was just under 20,000 lbs with 11,300 lbs on the trailer. The weight on the tongue was set to 1,200 lbs while loading the trailer. The next day I removed the hitch receiver and laid it out on the tailgate. In the photo below you can see the broken flanges (all on the left side) and one broken mounting flange on the right side. On the left side only one mounting tab showed a fresh tear, the rest had rust on them for some time. The right rear tab was also rusted, so it had been broken for a long time as well. This incident prompted me research hitch receiver ratings and hitch terminology in general. I was not impressed with the research results. Basically, what I found was that OEM hitch receivers on Dodge Ram 2500 trucks up to around year 2013 are rated as follows. These are maximum ratings: With Weight Distribution …..... 12,000 lbs trailer weight, 1,200 lbs tongue weight Weight Carrying …………………. 5,000 lbs trailer weight, 500 lbs tongue weight My neighbor and I used his 2011 Dodge Ram Cummins 2500 to rescue my trailer on top of the pass. We couldn’t use my weight distribution hitch because his hitch pin was frozen in place. It wasn’t until the next day that I realized that we had seriously abused his hitch receiver (maximum weight carrying - 5,000 lbs, maximum tongue weight - 500 lbs). However, after close inspection, all is well. One thing that sticks with me through all of this is that there is no safety margin with the OEM hitch receiver ratings on the years of trucks mentioned. The sticker on the hitch receiver is the only place where I found weight carrying information on my truck. There was no sticker on my neighbor’s 2011 truck. My owner’s manual had information about maximum load capacities with use of a weight distribution hitch, but no weight carrying information. The owner’s manual for the 2011 truck had no towing information and referred to the “ramtrucks.com” site for towing information. I have since installed a Curt 16,000 lb bolt-in hitch receiver which allows for 16,000 lbs towing and 2,400 lbs weight carrying (with or without weight distribution). May be a bit overkill since my trailer load maximum weights won’t change, but there certainly will be a greater margin of safety. My neighbor has ordered a 15,000 lb hitch receiver for his truck. Just thought I would share my towing experience and maybe trigger some hitch receiver inspections on some older trucks. - John
The last serpentine belt I installed was in 2014, approximately 170,000 miles ago. Still on the truck and wearing well. Never has made any noise. Can't tell you the brand, but it came from Geno's. - John
Hilary's coming to your place Mike...
Rain continues - up to 1.04 inches now. Moparman should be getting some of this rain. Our average monthly rainfall here for August is 0.75 inches. We were already well over an inch of rain before this morning's rainfall started. - John
Rain started about 5:15 am. Received 0.61 inches so far. The forecast is for 1 to 2 inches today. - John This is what radar has looked like for the last 4 hours. Rainfall up to 0.74 inches now. - John
It's all about percentages. You should take precautions. Your rainfall and wind speed could double or triple on a moment's notice. You need to be prepared. - John
Showing signs of arrival here in Baker City. Two thunderstorms this afternoon and evening with .14 inches of rain. Flood watches in effect Sunday and Monday. - John
To display the Hour Meter on your 3rd Generation Cummins
Does that work for all 3rd generation trucks?
