harg432@msn.com
  1. Complete disassembled main shaft nut loose-- washer hitting 5th gear syncro fork (aluminum) replaced nut -shift fork- 5th gear on main shaft
  2. I have aluminum flakes in my NV4500 oil looks like metallic paint What can be wrong? What is aluminum in the transmission?
  3. Contact Bob Wagner Paid $100 for reprogram ECU Had problems with Smarty Had to reset Smarty with magic numbers Works great made 8500 trip to East coast no problems
  4. Bought Smarty did not say anything about choosing a transmission
  5. thank you will any programmer do this
  6. Converted 2001 diesel to 5 speed no cruise cut black with white tracer The check engine light with code P1899 " P/N stuck in park or gear" then the truck would govern to 1700 RPM until code is cleared Help
