retirednak
  1. My bad,I just got out of the bath tub bitting at the bubbles,so my head wasn't in the game:banghead:. Sorry fellas
  2. The torque management is different then adding timing if I'm not confused by your TM4 remark,its a different setting all together. I wouldn't run the highest setting in TM unless you've built up your trans-clutch ect.
  3. Onced all flushed and clean,don't forget to do the filter. Most places around my neck of the woods 99% don't touch the trans filter. I asked one place why and was told since the trans now has all new fluid a filter change isn't needed. Most of the places were the quick lube type, change oil and filters and squirted grease when needed and of course trans flush. I even called one trans shop and was told the same thing,I won't ever go there for trans repairs.
  4. YourP0743 - Torque Converter Clutch Solenoid/Trans Relay Circuits P1693 - DTC Detected in PCM/ECM or DTC Detected in ECM ,P1763 - Governor Pressure Sensor Volts Too HI ,P1765 - Trans 12 Volt Supply Relay Ctrl Circuit ,. If it were me,I would head straight back to the stealership and see if they are willing to help. If not,check all the grounds on the truck. Make sure you clean each connection and not just snugging up the bolt ir nut. After that run a load test on your batteries,perhaps you have a bad battery. Look for any cracked,smashed or frawed wires. You might also try disconnecting both batteries for a half hour or so and see if the codes reset. Also try unhooking your Edge power adder and see if the problem goes away. I tried an Edge product before I went with Smarty,the Edge caused some electrrical grimlins to pop up that I couldn't live with. Double check the Edge connections. I don't know much about the older model trucks or trans issues so perhaps someone else can chime in and offer better advice. Electrical issues suck and tend to leave a bad taste in my mouth since I'm not comfortable dealing with them. You didn't say how long you've had your truck or how many miles are on it. Let folks know about the miles,it may make things easier in the short run. Don't give up,remember you bought an almost 12 yr old truck,issues will show their ugly little head. Good luck-Casey
  5. My '03 is a early model with the 250 hp engine and 47 series auto. I've got my best continued mileage running on 7,and set at 75%. I did have to rebuild my trans within a yr after buying my Smarty due to lack of common sense and a heavy foot. I've played with every level trying to reach the best possible mpg,one road trip this summer with kin folk loaded I reached 20.1 mpg. I'm usually between 16 & 17mpg running here and there. I've never seen the hide side of 18mpg before,so the sun and moons had to have been lined up right. If happen to lug the engine I will see some black smoke. If You have POD feature,you might want to try higher levels and reduce the power and see how your mileage goes.
  6. I had an EZ Edge for a while. If it has the removable pins for power adjustments,look for a loose plastic piece behind the cover of the unit.(2 screws) I moved the plastic do-da's depending when I towed and what not. I had to spread the pins a tad so the plastic do da's held firm. I used curved pliers to spread the pins. Since I have an '03,I didn't have a power wire nor ground to hood up. If you need instructions,you can go to Edge.com and download there,they also have helpful tech dept to answer any question. PM me if anybody is interested in an Edge Mileage Max.
  7. Since I don't have the money right now to convert to a 48,I'm going to have a local Mopar wrench rebuild my tranny with an upgraded TC and VB. Wish I could afford afully built mail order trans from the lower 48,but shipping costs are way too expensive.
  8. I've been trying to figure out why we get raped so bad here in AK. We pump it out of the ground,refine it in state and still have some of the highest fuel prices in the Nation. BP answered this question by saying since there is no competition between major gas companies in state,so it keeps fuel prices high. I may be a tad slow at times,but I don't understand this kind of reasoning. The state has supposed to have investigated price fixing here,but find everything on the up and up.
  9. Not sure if its a repost or not. I've always had a soft spot in my heart for the old PW. This guy has way more money then he needs! http://www.wimp.com/pickuptruck/
  10. Topped off my tank yesterday at $4.60 per gal,glad it only took $80 to top off.
  11. Thanks for the reply. For sure on the VB/TC,since I don't race or pull heavy any longer,I don't think a billet shaft is needed. I'll never see 500 hp out of my truck,I may be lucky to see 400 hp. Only other upgrades I plan on doing are LP and injectors when it needs it.
  12. I guess its the training wheels on my truck that makes my mileage so bad. I used to get around 10 mpg pulling 9K trailer at 55-65 mph. Running without a trailer I felt lucky to see 15 mpg. This was when I was running with either Edge Mileage Max or EZ Edge. Once I got the Smarty POD,nearly had a heart attack when I got close to 18 mpg. That was at 55 mph,damn it hard driving at those speeds!:banghead: I usually see 15-16 mpg running back and forth to town and a trip to Anchorage once a month at 65-70 mpg. I bought the truck in hopes of getting great mileage compared to my last gas pot,boy was I wrong. I'll never go back to gas again,just wish I could get better mileage. My wife tells me I drive like an old man and to put my foot into it. Until fuel prices drop below the $3.68 level,its gonna be grandpa time for quite a while. Hopefully my new trans next month will make a small difference. I wish I never sold my second gen truck,but rust was a big issue and couldn't find a clean one.
  13. I found a guy locally who will rebuild my trans for $22-2400 including the TC. If I want an upgraded valve body it will be on my dime.(I do want) If I member right,he said he uses BD TC and builds the trans to stock specs,but did say he has some tricks,like increasing the pressure,not sure of the other things he does when building the trans. He claims I'll still be able to run my Smarty on any level and pull trailers all day long. He gives a 1 yr warranty,plus I know where he lives. I'm a little worried about rebuilding without upgraded clutches. The heaviest I will pull will be my full size car on a trailer to the lower 48 and back.This fella works at one of the local Mopar stealerships as the trans builder. I've talked to one guy who just had his trans built by the same fella and is happy so far,but hasn't had a chance to pull his 5th wheel equipment trailer yet.What do you guys think about going back to stock with the upgraded TC and VB? Should I insist on upgrading extra clutches?
  14. I'm paying $3.56 just down the road in Knik, Anchorage drivers are from $3.26-$3.56. North Pole is hosing its customers at #3.83, in Cordova is $4.30. Some of the folks in the villages that are remote pay over $9.00 We explore,drill, pump our own oil,refine it,produce it and we are always the highest in the Nation,I'm done and over with it. My wife and me have been thinking real hard about locating to a less costly place to live,have 4 seasons and a person to have a CCW permit. We both have kin in Calif,but they won;t allow anyone to carry for the most part. We're scared of the economy being in the toilet in the lower 48. But we must have mountains,trees,ATV/off roding,winter only 3 months and it doesn't get over 85 degrees, And last,cheap Diesel. If you might have an area that sounds like what were after,please PM me. Thanks-Casey
