kerley
  1. It can and will if you attach the fuel line directly to the VP44.
  2. Your oil pressure is good for idle but for high speed I think it is low. I know my Cummins oil pressure is about 70-80 pounds at 60mph. I am not saying you have a problem, just mine is different.
  3. Thats what I did. I went to Car Quest and they did a good job for much less than half the money. I went with Red for Hot and Black for Ground.
  4. I am talking about the wiring harness from the oem push/pull light switch installed in the dash to the aftermarket trailer brake control box. There should be a oem harness hanging from the oem light switch that will plug into the aftermarket trailer brake harness, like plug and play. Is it possible that the 98 Ram 2500 did not have the oem harness when built? I do know on my 98 there are wires hanging down and hand wired and wrapped with black tape and my trailer brakes do not work properly. If there is such a harness available I would happily buy it to save the wiring job. I thank you members for helping me solve this mess. I did not do it but I have to fix it but I refuse to blame George Bush.
  5. Information Please, Does anyone know if the 1998 Dodge Ram/Cummins Dash light pull switch has a removable trailer wiring harness. Is the trailer wiring harness plug and play. Mine was altered by previous owner. If so can the oem trailer wiring harness be purchased and where? Thank you, Tom.
  6. Anyone buy parts from Rock Auto and were you satisfied ?
  7. Where did you buy the new 4" down pipe ?
  8. I looked at the web site where you bought your new ecm and there are many available, did you get the correct unit ?
  9. My fuel pressure at 65 mph is 23 pounds and I have had no problems to date.
  10. Are both your batteries holding the proper charge? How about your Battery cables ? I was having numerous problems with my 5.9 Cummins so I started from the beginning. New Batteries and total Battery cable replacement made a big difference.
  11. I can not find a code 1693 in my Dodge/Cummins manual, what vehicle are you talking about?
  12. I don't know but if it is like the rest of the crap they make it won't last. I think Mike has a wright up on rebuilding starters which would be very useful.
  13. AGP Turbo, This is not a personal attack on anyone, sorry you don't like my approach and don't brag, you were not the only member that donated $10. which was never my complaint.
  14. Excuse me joecol911, I re-read my post and said nothing about being "ripped off", $10.00 is nothing to complain about. What I am looking for if you don't object are the BoD rules and why I was e-mailed a notice that "If I did not reply with in 24 hours" ? so back to my origional question "What do you want, what are your rules?
  15. I am sure that I am not the only member that wants to know exactly what you want. First you notify members that you are shutting down this site, then you changed your mind and notified members that the rules have changed. Then you notify members that the minimum dues you expect is $10.00 for each six month period or member can not post. So myself and others sent you the $10.00 dues required to post. Today I receive your e-mail SR233- NOb Membership Requirements. Will you please explain to us exactly what these requirements are and exactly what you are looking for. This is not a personel attack on you or any one else, I would just like to know exactly what you want. Tom Kerley.
