Raffron
Everything posted by Raffron
  1. We do input our tire size and gear size. Does the speedo reflect these values in its output? Or is it only showing the speed the truck shows?
  2. Got question on I quad app. Does it average MPG at all? I see the eco. I see trip gallon. But what about average? In the data log mine says max99.99 in the MPG.
  3. 7 x .10 VCO? Any suggestions? Should I get Tubes also?
  4. https://www.dropbox.com/s/cf4r3pys9gblgth/iQuad-2018-04-20-09.33.51208901081.csv?dl=0
  5. I think I have this all figured out. Noticed oil dripping all around oil pan and New tappet cover. Checked oil last week and was high. Now it is really high!. Seems like it may be fuel in my oil. Gonna test it. Explains the no boost and the weird map sensor readings and the hard starts....... Can anyone read my datalog from drive home? I have to be in anti torque tune to achieve any boost. Leaking injectors?
  6. Where can I buy cummins parts? Gonna buy a new map.
  7. I was getting 30psi boost on a tune and now it won't reach 20 unless in anti torque tune. It only hits 5psi. 2000 dually.
  8. I thought the 01 pcm was the issue. But seems it doesn't have anything to do with the signals from map or apps. I think the map sensor is bad again. What would be killing the map sensors? I just replaced last week.
  9. 2000 dually.
  10. Ok. So it seem that a while ago the guy at the local diesel shop showed me a weird code that was saying the pcm on my 2000 manual truck was from a 2001 and his reader was having issues because he had put in that it was a 2000 so it wouldnt let him see the vin. Now i am thinking that the 2001 com is looking for different voltages (hence seeing 2psi boost on quadzilla while the mechanical gauge sees 10-11 ) which explains no smoke on anti torque tune...? ! RIGHT? Hmmm. Any input?
  11. I get off at 7pm . I will give more info then. Thanks guys!
  12. My truck runs smooth and clean in the anti torque tune from the repository. My question is this. Why does my quadzilla shows 12psi when my mechanical gauge shows 20+? And could this be why the only tune that acts right is the anti torque tune ? Just replaced map sensor. Not a cummins sensor.
  13. How did you get that number?
  14. The iquad minimum is 95. 7 inches. Not sure how they are getting this number
  15. 285 75 r16. Does anyone know this in inches? Thanks
  16. Good luck. Are you just grounding each to a battery?
  17. i dont see a torque management tune . I see it... Thanks. How do I load this ADR9802V2.7 MPG Release Final 2.7.7
  18. I really dont want to piss anyone off. Just to play with while at the mud bogs with the big boys and their toys. I agree smoke is what gives diesels a bad wrap.
  19. i didnt see any smoke tunes or lope tunes for the v2. Any links on the site? Just for fun. Not for DD
  20. What is the power reduction setting? You guys have it in the first page. I dont see it in my adrenaline. What the heck?
  21. Yay! I got it figured out. The map sensor was bench testing at 5v in and 5 v out. Toast! New one in and boost back. Now I just need a good tune for it. Thank you everyone for all the time and input. Now where is that button to donate?
  22. I am not retapping this pump.. but I am gonna Check wiring again. I do the that the quadzilla is on at least. Thank you for the advice.
  23. I do. But it is not hooked up. I am sitting at 19 idle and wot 17. I am gonna go buy a scan tool now. Brb I read codes. P0237. That's it. Will not erase.
  24. I am sitting at 19 idle and wot 17. I am gonna go buy a scan tool now. Brb
  25. Thought that also. Checked that before I bought new vp44. The turbo is not spooling . I will post codes tomorrow after I get them. I feel like the quadzilla boost fooler isn't working. Or maybe map sensor went bad again.
