LegendaryKing
Everything posted by LegendaryKing
  1. I have now driven the truck a few thousand miles, towed a large percentage of those miles, some of those towing miles were on 6% mountain grades, and the transmission just gets better and better. In the begining it was on the stiff side to shift and it took quite a bit of time to shift. Make no mistake, it wasn't difficult, and didn't feel bad, just stiff and slow. Now, the transmission is MUCH less stiff and I would say is 30% faster to shift. It's no race transmission, but I would say things are actually better than when stock. I'm very happy with how everything feels and functions.
  2. Finally got the truck back from trusted installer. The owner of the trusted installer shop took a class and got trained on manual transmission rebuilding just to fix my truck. Turns out the only thing wrong with the transmission this time was the input shaft wasn't shimmed properly. Transmission now shifts great. I'm letting the truck sit for a few days and then I'm going to go fire it up and drive it cold to see if it still shifts great. Owner of the trusted installer shop says it shifts great cold or warm. This is the happiest he has been with the transmission. Trusted installer's opinion: transmission would shift a whole lot better with a factory clutch over the dual disc, but acknowledges the dual disc will outlast and out perform holding power of a factory style clutch. Since this isn't a "race truck" or a "street toy" where super fast shifts matter the whole package will probably serve me well for years and miles to come. While it was there the list of items repaired was: All ball joints Control arm Hub & bearing Allignment Thermostat Front/rear diff and transfer case fluid And I know I'm forgetting something but I'll update this thread in a few days. Truck drives straight as an arrow. It almost feels like the newer modern trucks ... 80% of the way there. There is a little bit of play in the steering box but that is to be expected on these trucks. I have a steering box brace to help with the box deflection, but the box itself is on the worn side. It's not too bad yet and I'm still recovering from this bill maybe at a later date I'll think about a box, but right now the truck drives so good it's not worth it to me.
  3. Brutal is the fact that I haven't had a working truck since August 2018 with what should have been a SIMPLE clutch replacement.
  4. Update: I still do not have the truck back. Report from Trusted Installer: Transmission still isn't right. It comes out of gear when you come off throttle and back on throttle. Transmission re-builder Trusted Installer subbed out to is now out of business. There is a dumpster out in-front of the building and the owner is nowhere to be found. Trusted installer is planning on tearing down transmission and rebuilding from the ground up. I was given an estimate of approx 8 additional weeks until complete.
  5. Thanks for the advice. Anxiously waiting on tips to conceal carry a 30cal rifle and a 12g shotgun at the same time.
  6. I want to safely lock up two long guns in the cab of my truck. The storage solution must be lockable with a high security keyed lock or a pad lock option so I can use my preferred lock. Bicycle cable solutions are not acceptable and while not 100% necessary concealment is preferred. What is out there? Everything I have personally seen is either pistol related or specifically for third gen trucks.
  7. Update: Report from Trusted Installer: Rebuilder decided transmission on first rebuild was so clean and complete only 1st and reverse syncro needed replacement so that is all that was replaced. This is contradictory to what Trusted Installed requested, which was to replace all the syncros and bearings. When the trusted installer took the truck out for a test drive the 4th gear syncro shredded. All other internals look perfect. This time new bearings (again), and ALL syncros were replaced. Hoping for truck delivery sometime next week.
  8. Update: The rebuilder finished with the transmission and returned it to the trusted installer. Report from rebuilder: Transmission looked brand new. No unusual wear patterns on the gear teeth, everything looked almost perfect … except for the syncros. New syncros and bearings were installed; the transmission was re-assembled with new input shaft and sent to trusted installer. Report from trusted installer: Installed transmission and took for test drive. Transmission shifted like butter. One of the nicest direct shift truck transmissions he had the pleasure of driving. HOWEVER, on the test drive when he released the gas pedal at 1,500 rpm in 4th gear there was a whirring noise under reverse torque (deceleration) followed by grinding. The transmission would no longer go into 4th or 5th. After a few applications of the clutch pedal, the transmission would go into 4th and 5th gear but not without “grinding”. Transmission rebuilder inspected trans while in truck and said it had to come back out. When the trusted installer drained the fluid it had LOTS of “glitter” in it. Truck is still waiting on the rebuilder to finish the transmission. I have not hear anything since this past Friday. We are at the beginning of week 3 since trusted installer removed transmission and sent it off to rebuilder. Tags just came due for the truck and that is a kick in the wallet, as I have not had a working truck for a year.
  9. The insurance company of the driver that rear-ended me just informed me they are not responsible for my personal injury medical bills. When you're going through hell ... keep going, that's no place to stop.
  10. The installer is pulling and re-installing the transmission. We have a good relationship as I have known them for 25+ years. This is not their fault; this is all due to the original installer royally screwing up a clutch replacement job. The original installer who caused all of these issues from the beginning is unavailable for comment. The installer sent the trans out to a local guy that apparently knows this transmission inside and out. It comes with a 2 year unlimited mileage warranty. As I said, I trust THIS installer as I have known them for years, if they say the re-builder is good I believe them. I'll update once I get my truck back. Hopefully my shoulder/arm/back will be healed up shortly so I can drive a stick shift. I was rear-ended in the wife's crossover suv and my arm is in a sling. The good news just keeps rolling in doesn't it?
  11. Update: Transmission is out getting rebuilt. Here is the lowdown: Apparently the input shaft was damaged on the initial install and that damaged the pilot bearing and the throw out bearing. Everything was so galled up it was difficult to get the bearings off the input shaft. I'm told the Dual Disc looks clean and should be problem free. The pilot bearing, throw out bearing (TOB), and input shaft are trashed. Ordered all new parts from DAP. When the transmission came down, there were TONS of brass shavings around the shifter, in the fluid, etc. Apparently the TOB wasn't releasing causing the input shaft to continue rotating and destroyed the syncros. I hope this helps someone in the future because it has been an expensive HUGE pain in the ***.
  12. Hydraulics passed the tests and the clutch is coming out of the truck.
  13. Spoke with the good people at South bend and they gave me some diagnostics to run on the hydraulic system. The test is found on their website. If the link breaks it is under resources and is called Hydraulic Testing. According to South bend I'm running the exact fluid I should be (Redline MTL) and it is apparently normal for the dual disc to have issues going into reverse. It is recommended to shift the transmission into 4th first, then reverse. Seems hokey but at least it's expected. South bend recommends AGAINST running thicker fluid as it has a high probability of pushing/blowing out transmission seals. In addition they believe my cold shifting problems in forward gears could stem from the hydraulics and I have one or a few problems. 1. installed wrong, 2. adjusted incorrectly, 3. bad and require warranty replacement. The shop that installed the clutch correctly will be looking into the hydraulics (South bend hydraulics and installed by previous shop) in the next few days when they have time in the schedule. I'll update this thread when I hear more, but I wouldn't be surprised if the hydraulics were installed incorrectly by the previous shop.
  14. So putting thicker oil in my transmission isn't going to improve my shifting problems, there is more than likely a mechanical problem with the transmission that needs to be diagnosed? Thinner transmission fluid would make the transmission shift better, but will reduce the life expectancy and since I'm already running Redline MTL I'm at the thinnest I can go so time to start looking at hard parts and stop swapping fluids around?
  15. Shop thought the same thing (thin fluid) and wanted to do a drain and refil to make sure the trans fluid was ok. Did a drain a refil with Redline MTL. The truck had Redline MTL in it before the drain and refil. No change. After a mile or two of driving all forward gears shift like butter. Is Redline MTL too thin? If so what is the recommended fluid for a trans with dual disc? Doing a fluid drain and refil is a lot easier than pulling the trans out again.
  16. And I spoke too soon. When the transmission is cold I get a grinding noise when shifting and the transmission ALWAYS grinds going into reverse. As soon as you put a few miles on it the trans shifts into fwd gears without issue. It has Redline MTL in it and my shop is telling me they think the syncros are toast and it might need a rebuild. What do you guys think?
  17. Did your filter stay dry?
  18. Most likely wet filter element. With as much as I have my hood open when its raining I think the few extra dollars is worth the protection some mesh can provide against the filter entering my engine. Also, good information about the filter minder from the source: http://filterminder.com/resources/learn-more/39-resources.html
  19. Anyone running the fleetguard AH19004? It is the marine BHAF with the mesh on the inside to keep the filter from collapsing.
  20. UPDATE! My regular maintenance/repair mechanic is an obsessive compulsive perfectionist. I drove my truck last week because he didn't like the "noise and vibration" he was getting from the trans. It's actually quieter than when it was stock and has less vibration (almost zero) through the shifter. It's actually a little on the disappointing side as it use to feel like a truck, and now the clutch/shifter/noise feels civilized. I believe that is due to a proper install and a high quality clutch. I wonder how much more mass/dampening you get from the twin-disc over a factory clutch? I had a few other problems that are getting repaired but I have to wait my turn in line so hopefully the truck will be ready soon but at least I'm out of the woods.
  21. Shop got the trans in and are working on some other minor issues (4wd, etc) however they mentioned they are hearing a rattling/vibration sound while accelerating in gear. Anyone got an idea what that could be?
  22. I change the factory filter with every oil change. I use Baldwin filters for oil and fuel as they are manufactured in the USA where Fleetguard is manufactured in Mexico.
  23. I have the tools, ability, but not the time. Wish I did. Had you said something before I would have taken you up on this challenge. ;) Life lessons are painful from time to time. Even if you choose a shop that has a good reputation, with lots of examples of excellent work, you can find a problem from time to time. A truly good shop stands behind their work; thankfully the shop I have running cleanup on this job does just that.
  24. Where to start? The performance shop that installed the clutch did not have availability to check the install and said it was fine/normal operation. Very acceptable right? They are now out of business. That was not satisfactory so I dropped the truck off with a regular maintenance shop run by a family I trust. The list of problems the new shop found is long. First, the flywheel had cardboard between it and the crank so it was not on straight. In addition the bolts were finger tight … yes FINGER TIGHT! The clutches were not installed in the proper orientation (was organic towards center) and the clutch fork had a bright yellow sticker on it which stated, “Remove the washer before installation” … the washer was not removed. Several bolts were missing from various places on the transmission including bolts that held the transmission to the block, top cover bolts (the transmission was leaking from there), and several other places. I will have to look at my receipt for all the mission bolts once I get the truck back. In addition, the previous shop dropped the transmission on the front diff actuator (broken) and crushed some of the metal vacuum lines, which disabled the 4-wheel drive. The previous shop also killed both batteries in the truck, and instead of fully charging or replacing the batteries they jump-started it and the alternator could not handle the additional amperage of trying to charge two dead batteries so it welded itself solid (that is why I needed a Mechman alternator). Upon replacing the alternator, the shop broke my fan shroud, and somehow in this space of time broke my hood light. As of Friday, the transmission is back in the truck and the shop is working on fixing the 4-wheel drive. The shop wants to take it on a test drive to see if the shifting is better (it was HORRIBLE to shift) or if additional internal work needs to be completed such as shift forks. They believe all the issues due to the atrocious install were the cause of the appalling shifting, vibration, and noise and additional internal work is not necessary; however, the shop needs to complete a test drive to verify that.
  25. I have run alternators with smaller pulleys for years on cars that rev to 7k plus. The 3250 rev limit on our trucks shouldn't be a problem.
