ramman 01
  1. are you sure it is 0382 and not 0381? I can't find 0382 in the list of codes but 0381 is there which is glow plug /heater indicator circut (wait to start lamp inoperative ) if this helps any
  2. $ 1.37 per litre up here
  3. hey flagmanruss, after reading your last post i just remembered that the same thing happened to me and it ended up being the fuel relay in the box on the drivers fender so i just pulled my foglight relay and put in the place of my fuel relay and she has'nt stopped since.(After about a week of searching for broken wires and bad grounds)
  4. if thats all you need for the air dog then i would go that route.When i got my fass it came with quick connect fittingfor the tank so the only thing i had to do is pull the existing line and shove the new one on.I had to clamp it at the tank and the rest were push lock.I think the fitting are only 4-5$ per
  5. Russ I agree with JOHNFAK. That is still high as two years ago i had to replace mine on the motor also and i got one for around $170 from midwest diesel and it only took a half hour to 45min to replace so they must be charging u $300 per hour.ouchhhhh
  6. i would get a 2nd opinon if the lp not working the where did the spray come from when your buddy cracked the schrader valve and $1200 seems quite pricey to me
  7. ya that's what i thought . not sure how he did'nt notice something before it got that bad.i know these are loud but he should have heard some major thumping going on
  8. Wagntagn there are several different gauges out there to choose from but i am in the same bout as you so after doing some reading i decided tomorrow i'm going to oder the 3 in 1 gauge from glowshift. Just google glowshift performance and i think you will be able to find something happy to hear you got her up and running Kevin
  9. Joe thanks fer that imfo as i will be putting the truck in the garage tomorrow and i will try that
  10. hey Jim Thanks for yhe reply . I think i will try the wire trick and if that does'nt work then i'll give the #4 a try. I realize the question has probably been asked several times but i am not that familar with the site to know how to get imfo on a particular subject without reading all the threads until i find out something about it so from now on i guess i will have to ask less questions and do more reading thank again Kevin
  11. i have also tried to move my waste gate by hand with no success so on a stock motor how can i tell if my waste gate is siezed or not.I don't have any gauges yet so should i be able to tell some other way like how the truck would or would'nt performe.On monday i am going to order the 3 in 1 gauge from glow shift with fp , ext and boost .
  12. when you put the 2 in leveling kit in will this effect steering or tire wear in any way ?
  13. thanks ,maybe if i get the chance this weekend i was going to pull the wheels off and chech the rear calipers so if i have the time maybe i will pull diff cover as i never thought of that one.This is why i decided to post it on the forum to see what other ideas were out there that i did'nt cover.Oh ,i see that you have a glowshift fp gauge and was wondering how you like it because i was thinking of ordering one for myself.
  14. that would be an idea but the pillow is attached to the bed:lmao:
  15. the only way i can visualize it in my mind from sitting in the truck when i feel it is if you were to put a bean bag in a cement mixer when it gets to the top of the drum it falls to the bottom making a thud and then when it makes another half rotation the same thing again if this makes any sense
