Eliecerserrano
  1. Hello im from panama and my truck was stolen but i get it again i have a power commander pc 30 but they cut the wires and take the pedal ?and other parts my problem is i have the power commander but i want to connect with my truck but i don’t know how the wires color going if somebody have this system and can send me pictures Please
  2. Eliecerserrano changed their profile photo
  3. Sorry wrong pic...but i was looking for the cable color the positive and negative wires
  4. I start my cummins but the gas pedal dont work
  5. I have this tag from the rear differential i need to know how it call this differential somebody say dana 80 but i trying to find with any results thanks
  6. i want to know what is the dana number of my 2005 dodge ram 3500 2wd beacause i hear the sound on the differential and the mechanics say is the bearings beacause the ring gear and pinion looks good thanks in advance
  7. D7771714-B91F-47D4-BA37-75F2A695966E.MOV
  8. maybe that help...well today i move al the cables and stuff to the other engine and dont start but the fuel pump do the click but dont send the diesel to the injectors? Because i open the last and dont have diesel...weird monday im going to move the injection pump to the engine and try again
  9. i have good news today i try to start the engine and yep its alive!!! the cables on the harness to start are red/green red/white tan/red i connect the electric pump directly to the battery here is the video of the old engine tomorrow i try with the other engine WhatsApp Video 2018-01-05 at 1.57.06 PM.mp4 now i need to find the cables of the throttle pedal position because the gas pedal or the cable pedal dont work
  10. well i try the best i can and nothing work maybe i should wait for a fuse box and connect the wires to try because the engine still crack but no run
  11. when i crank the return line just give me in about 1 min just like 10 drops thank you for all your help i hope i can try tomorrow i let you know if this work now im going to read
  12. yes at the first trying just air and diesel then a lot of diesel come from the lines
  13. yes i do that and it split on my head diesel so i know for sure the fuel pump work lol i just use a lil bit of starting fluid and the engines sounds like is alive but when i stop spray it shut down
  14. its not installed...yeah i have some of the wirings so tomorrow maybe i can do another trying almost all the sensors are connected just the fuel filter have 2 but they are diferents
  15. the ford fuse box is not with the engine just imagine i have the 2 engines with harness but i dont have fuse box i try many times to start just with the 6 cables to the battery the fuel pump work and the vp44 click so that tell me maybe he is right..... the pump send diesel to the injectors but i feel i miss something like when you turn the key to start something like that i know i dont have any other cable from the inside
