SIlver_Bullet1997
  1. I feel like timing and fuel stretch have to have some effect in it
  2. I guess I don’t understand how every tune gives the same hp top but changes how you get there
  3. I do already have v2 tuning, I’ve got my tunes for my truck but don’t race much and not looking for a lot of power usually but on a dyno and the new parts I wanna see what the old girls got.
  4. I have a s363/68/12 sxe turbo, 7x.010 injectors, studs, valair dual disc, and v2 tuning. I’m looking for someone with a similar set up who has good dyno numbers and a hot dyno tune to run on the truck along with maybe using it on the street. Thanks in advance.
  5. How would I check for when it’s opening? It’s gated for 45psi but I’m limiting it to 40 or so, think I could still have a boost leak?
  6. @Mopar1973Man it’s got 3.54’s with a NV4500, 4x4,
  7. Hey, sorry late reply but I had a boost leak that I found today. This should be a better graph for you to make and get better results. This is my Daily tune I use driving empty. There are a couple full throttle pulls and some cruising as well. My turbo is a 63/68/12, with 7x.010 sac injectors. I’m running a leveling kit with 33x12.50x20 mt’s and 20x12 wheels iQuad-2018-04-30-08.26.32.csv @Me78569
  8. iQuad-2018-04-29-06.26.06.csv
  9. Someone else should correct me if I’m wrong but for v2 I’m running 2.5? Try that and see if it makes a difference I thought I read something about 2.7 having problema
  10. Someone else should correct me if I’m wrong but for v2 I’m running 2.5? Try that and see if it makes a difference I thought I read something about 2.7 having problema
  11. Once I get around a windows computer I will try this for sure! Hopefully it works this would be awesome Tried, but that’s All that pops up after I hit download. I don’t have a copy option st all
  12. So have you found a good way to import the quadzilla tune to the IOS app? When I try to download the tune via safari all I get is this Let’s hear it buddy! I’m looking to import some tunes for my new set up
  13. Loooking to put these tunes on my quadzilla manually but can’t download to see parameters can anyone help me?
  14. Thanks a ton guys! I think I got v2 tuning now!
