Steve31
Everything posted by Steve31
  1. Wonder if something else had happen to it then.... maybe a bad jumpstart or alt surge? I can mat it and start leveling it up and it’s very suttle if any change at all, may just order a stealth plate, ensure a good connection and get the rigged up look outa there
  2. Did that it does have 12v I did read somewhere if a quad is unhooked for a long time they can get a little glitchy, when I first got it the backlight and half the features didn’t work and would freeze the unit up, using info from this site I updated/flashed the display it self and everything works now, just wondering if the main box may need the same....
  3. Thats why i been thinking of using a dedicated droid device S4 Active and trying to make a pillar pod for it, IDK might be more trouble than its worth
  4. I have a similar problem, Im pretty sure my wire tap is not working any thing past lvl2 has no change, Mine does still have the display (pv1 i assume)
  5. Been thinking of going with droid cause I believe I can make a launcher so when the device is powered up it goes straight to the app
  6. I’d love to update to v2 but on the other hand I like having my hardwired screen. wish they would have an option for an updated full color screen something better than the edge screen, it would pull more attention to quadzilla for sure
  7. I just leave it at the 8* and fueling at 1400, seems to like it although I rarely run it higher than lvl 2-3
  8. Stupid insite removed all my cal files said they where to old ?
  9. Really just by feel but I do have ecm images saved I could open with calterm to get numbers
  10. It’s set on 8* by default, bout the only thing I’ve change was the max fueling from 1200 to 1800 I’m pretty sure the super chips I had on it before the quad had a lot more timing... so it seemed
  11. 100hp dap injectors @30 psi boost on stock head bolts kinda wondering what’s a “safe” point for as max timing and fuel
  12. Ok since yall twisted my arm so bad I think i will just order iquad module .... gauges should look sweet on my ipad pro lol Then I can do custom tunes the easy way
  13. Buddy of mine owns and runs a local injection shop here, and warned me about those ebay injectors, said he had a few sets come threw and the metal is really soft and wear really fast I bought a set of dap 100 nozzles (which he pop tested and set) and love them
  14. So in other words the pv1 really isnt stable to update (so to speak) But the new firmware (v2 for iquad) has the bugs worked out? The thing with mine is it wont hold settings, evertime you cut it off I have to reset the power level half the menu is not accessible ,backlighting, fuel press warning etc. it will freeze up and will have to cycle the power to get it back. And imo droids kinda suck, used to be a big fan of them until these last couple years, there just not near as stable as they used to be
  15. I have been looking to update my pv1 have read the thread about doing the updates but the tuning files are not available (page is down) Should I just send it in or does someone know where I can find the files?
