Daleb
Everything posted by Daleb
  1. The Cruise light on my 99 is not with the odometer. It is in the same location as what Leaky88 showed in his manual. The bulb is also replaceable. Dale
  2. Thanks module master looks good.
  3. Where did you get the abs module repaired. Mine needs repair. Also I have heard you can still buy new module from dodge anyone know if thats true.
  4. Thanks I will look into that.
  5. I checked with Dorman and they only have pins for the front doors. I will probably drill them out to the same size as the front and use the front pins. Just find it funny you can buy them for the front but no one has rear pins. They must seldom need replacing. Dale
  6. Hi has any one found a hinge pin rebuild kit for the rear doors on a 1999 ram 3500. I talked to doorman and they make nothing for the rear doors> I also checked LMC and Rockauto and they don't list anything for the rear doors hinge wise. Dale
  7. I will get a 190 installed this weekend and see if that brings the gauge up. The gauge might be off also I have heard some aren’t real accurate. I should plug my edge in and see what in getting at the diagnosit plug. Dale
  8. R no they come in F. Thanks for all the reply’s I will get a thermostat and see if it makes a difference. Dale
  9. Is this the normal spot for the temp gauge to run or should I try replacing the thermostat?
  10. When I got the truck the fuel pump was in the fuel tank and was powered by the battery and the relay was triggered by the original connection of the ecm. When I put a fuel gauge in the truck I only had 6psi fuel pressure from idle to wot it never change so I bought a fass titanium and 1/2 inch fuel line. The pump is ran off the battery and the ecm triggers a relay and I run about 18psi. Now as for the head light problem they come on with the key on. With the key off they come on when I put the parking lights on. If I pull the head light fuse they stay on really dim. If I disconnect the day time running light module the lights go out but if I turn the head light switch on it still kills the motor if running. If I take the #1 50amp battery fuse out I can turn the light switch on with out killing the motor but the head lights are still on.Also I have no blower motor or speedo but all other gauges work and I'm not sure if the problems are all related.I am in the process of finding a good 2nd get mechanic because I think this electrical stuff is beyond me.
  11. Amsoil has this
  12. The worst wires in the damaged pdc I have are melted at the wire thats goes to the fuel pump relay. I wonder If the damage was down when one of the original engine mounted ecm powered fuel pump failed and heated JC2. Maybe it was slowly deteriorating over the years until it failed. Might explain why there seam to be a bunch with the same damage. All my fuses in the pdc where the proper size but who's to say what was in there over the years. Dale
  13. thanks I will try to see if lights work normally with key off.No the truck does not have fog lights. Dale
  14. Good news I got the truck running was a loose plug in the engine line out harness. Bad news is the head lights stay on and if I turn the head light switch on the truck quits. Also getting code p1689. I cleaned all the grounds as I installed the new harness. The head lights are on as soon as the key is on and the high beams don't work anyone know what other grounds could be the problem or might this be another problem? Dale
  15. I was just thinking if JC2 goes bad should we not be able to bypass it and run the wires to a new fuse block and join them there. Or does JC2 serve another purpose that could not be served by fuses?
  16. Well there is a 98 24v in my area that just had his joint connection 2 burn up. That makes 2 total failures in the last few months also I have one here off a parts truck that got hot enough to blacken the plastic and have looked at a few others when I was shopping for my new harness that were the same. Im starting to see a pattern here that I'm not liking. Wonder If the early 24v are going to start having issues you all might want to pull the pdc off at the bottom and inspect joint connection 2 for signs of melting plastic.
  17. I thought the extra stuff under the dash was for the starter but its not because the starter works without it being hooked up. the light blue wire on the steering column is what its hooked to. Im going to have to trace the wires and see where they go. Cummins mechanic told me what to test on ecm to see if its getting power I will do that tomorrow.As for the wipers A bad ground can cause that sort of problem they seem to work fine now. This truck is quickly working its way to a ppump.
  18. Im going to check all the connections today because I had the connectors unplugged. The lift pump is powered off the battery and uses the original factory connection to turn it on through a relay
  19. Well hooked the batteries back up. The good news is that joint connection 2 stayed cool the bad is no wait to start light or fuel pump and could not pull any codes so looks like I might have to send my ecm for repair. Lucky these wonderful site has a list of good repair shops. Dale
  20. I must say thank you to you all here for your knowledge and patience I really appreciate it. Dale
  21. I looked at the old pdc and the worst melted wire came from fuse 3 eng control 2 and then to the grid heater relay. The relay was in bad shape when I removed it was cracked badly but was still working. Could it have back fed up into the joint connection 2 and caused the damage weather instantly or over time? Dale
  22. This might be it . I remember last summer shortly after I got the truck I was looking into the A/C not working and I pulled the fuse and one side of the fuse was broke and seized in the connector. At that time I remember something drawing my attention to joint connector 2 but I have a bad memory and can't think of what it was. The only other thing that I noticed when I was replacing the wiring harness from the pdc to under the dash is that someone has installed a fuse block thats feeds a solenoid and is powered from the battery. I think someone has made a starter circuit but won't know till the battery is hooked back up to see if I'm right. If they bypassed the starter circuit makes me wonder what happened to make them do that. They left the starter fuse in and the relay so If they have bypassed the pdc stating circuit should they not have removed the fuse and if that is the case guess I should track those wires down and see what they at the end. Dale
  23. One of the heavy equipment mechanics at work said that bad ground could easily put the extra stress on the pdc to cause it to burn up. The day this happened the wipers started to come on by themselves at the time I thought it was a bad switch but that is also a sign of stray voltage from a bad ground. Im hoping thats what caused it because I have found no other explanation that's why I have been paranoid to hook the battery backup and trying to troubleshoot before I do. Dale
  24. This is what I think caused the melt down a bad g100 ground. Im just trying to cover all my bases before I hook the batteries back up because it was difficult to find a good pdc and don't want to fry this one.
  25. I did some testing with all the fuses in the pdc pulled.still get full power at the 50amp battery fuse no matter what but i think its because its hot all the time please correct me if my thinking is wrong. Next the 20amp engine control 2 fuse has a slight draw. If I unplug the first connector the one closes to the motor of the pcm it goes out none of the others pcm connector make a difference so. Do you think that there is a problem in the pcm? The only other slight draw is from the 40amp abs fuse and it goes out if i unplug the abs pump so something going on there that I will need to look into. Looking for so feed back on what I have found so far. Thanks Dale
