No signal to starter solenoid
Had the PCM reflashed, nothing I have no voltage to terminal 30 from pdc fuse 2
0 vdc/No voltage at 30 with key in off position. No continuity from fuse 2 terminal to 30. Verified 12v at feed of fuse 2. Looks like an open in the pdc
New relays, Another thing I noticed, no fan and radio dies when key cycled to start. Pulling codes now No codes
Yes
If I bypass the relay and have someone turn the key it starts. New position switch on left side of transmission. Transmission shop rebuilt trans last week. Could it be the position pawl is not engaging correctly? Can I check if I pull the pan?
My "new" truck!
Morimoto HID INSTALL
I like it. Still need to adjust the height if the beams. I also am waiting for the Lee flasher to arrive so I can take it in the road.
- Morimoto HID INSTALL
Found the problem, bent pin in the main headlight connection, thanks to Jeremy from retroshop.com for walking me through the troubleshooting- Morimoto HID INSTALL
Ok I must have missed something, I only have high beams- Morimoto HID INSTALL
My ballast mount for the passenger side. I used countersunk hardware for the ballast, 3M double sided tape for the other black boxes- New Front Bumper for the TOW-PIG
banzaitoyota
Joined
Last visited
