Losing power? Cutting out?
I noticed today it’s actually the airbag light that comes on randomly while beeping.
Not sure why I didn’t get any notifications about this. I miss spoke when I said it does it until warmed up, even when coolant temps have reached 190° it will still do it. I have to drive for at least 20-30 mins for it to stop, and it will only drive normal again if I shut off the truck after that 30 min and back on. It does blow white/grey smoke when it’s driving bad, and black or none when it’s driving normal. I have no codes when this happens. Just a random check gauges light flashing every few minutes and rpm and speedometer will switch between working and not working. Sounds like timing changes or something when the rpm gauge drops to 0. Only reason I also suspect vp44 or just the psg is to my knowledge it is stock. So that’s 350,000+ miles. I know for a fact it has at least 200,000 on it Also the injectors have about 30,000 only. Fuel pressure is about 18 idle and 16 under any load
Guess you were right, finally got ecm back and so far this morning it’s driving like normal. I do notice still under moderate to heavy throttle it cuts out a little until warmed up.
Okay, I don’t know much about electrical but I’ll give it a shot when I get my ecm back from being tested. I replaced my trans output speed sensor and it fixed my problem shifting from 1-2 in the mornings. Im still unsure if it’s Ecm or Electrical at all, only because it’s fine once I get up to speed for a little bit. Then it’s fine for the rest of the day. I noticed a couple months back I was hauling some horses and I had to cross a wash with some deep sand and the back end just dropped, I tried 4wd and was still stuck, so I unloaded the horse and had to back up a little and pretty much floor it out the other 20 feet. I noticed when reaching between 2600-3000 rpm it sounded like a miss fire, the rpms dropped when it sounded like it, and blows a little white smoke. It seems like it de fuels for a second before jumping right back where it was. Could this be an injection pump issue? I don’t usually get that high rpms often but when I have to it does the same thing. I only wonder about the Vp because I think I’ve read some people saying that the temp of the injection pump it’s self could be causing the issues?
Okay thanks for the help. I haven’t had much time lately to look at it until today so I’ll run those tests. I cleaned all grounds again and changed both batteries. The Problem still only happens in the morning until I drive about 20-30 min. Then is fine all day. My fuel pressure gauge just showed up last night so I will relay that info as well.
One battery did fail so I replaced it. Driving normal so far but it was warmed up already. Check engine light is off and gauges seem to be working properly
I’ll check that connector, Batteries are clean and bought at the same time about a 1 1/2 years ago. They are Walmart batteries though so I will go get them tested right now. I’ll check out the ecm later as well, although it is less than a year old. I haven’t unhooked the quadzilla yet either but it’s also a year old or less. Same with airdog, which is powered by batteries with a relay. Probably 50,000 miles max on all the new parts. Lastly no fuel pressure gauge yet. I plan on ordering the kit for the quadzilla. I’ll stop at autozone and get a manual gauge for now to check my fuel pressure. Thanks for the help. It seems to be getting a little worse everyday. But after about 20-30 min of driving the problems seem to go away. Until the next morning I did replace my radiator and it seemed that very soon after if not the next day it happened. Maybe there was some wire I could have hit and unhooked or ground I accidentally broke. I’ll give it’s good look over today. I also noticed my fuel gauge was reading wrong for a day. I filled up and it said 3/4 when I knew it was full. This was yesterday. Today it’s all the way full where it should be.
No change with fuel cap off. Today I did have 2 more symptoms, ABS light flickering randomly and rpm gauge dropping to 0 when it’s not actually at 0
With a scanner I’ll give it a shot when I leave work today and let you know how it goes.
I hope it’s not the ecm. I’ll send it back to get tested. It’s not even a year old.
Everyone post a picture of your truck!
Okay oil pressure is normal after replacing it with an old one I had. Coolant normal as well. The only issue is p1698. It cuts the throttle so much until I get about 12 miles down the road and it’s fine again. I’ll post a video I took the other day of what it was doing. I was at between 80-95% throttle for the entire video, that’s how it acts unless I give it about 10% only. Then it will drive normal, until about 12 miles of driving, then I can give it any amount of throttle and it drives fine.
Another symptom today was check gauges light because oil pressure pegged at 100 and coolant keeps changing between 190 and 240
Yes exactly, So just like yesterday I went out after letting it warm up about 5 minutes. Anything over 10% throttle and I lose all fueling and it cuts out like 0. But my scanner still shows the correct throttle %. So if im giving it 10% and it cuts out, the scanner still shows 10%. None of the live data I can read seems off. I was thinking it’s a PCM issue and it’s not getting the signals from the trans correctly. I’ve checked all my connections and wiring to the pcm and everything seems fine. It also threw the same code this morning and my rpm gauge dropped to zero then back up to normal before the light came on.
I can say forsure once everything was warmed up the problem is completely gone. Once everything’s cold. I can barely move. The cut outs are very abrupt and rough kind of like accelerating then dropping into neutral.
