diesel pap
  1. since i posted last i have sold several hundred sets more.
  2. i understand that. i tow too heavy for a gasser.
  3. once deleted they are good trucks
  4. nope just the 1 code generator something.
  5. the only code i had was a generator code. i did not have the code you are talking about. after i changed the alt and started the truck up it was not charging. i got the smarty out and had 1 code generator something and it cleared. then i started the truck again and charge was normal. keep in mind when it quit charging i got this code and it would not clear. only after i replaced the alt.
  6. the code i had said generator something. i am still wondering if i broke down along the road if i could have changed the alt out then drove home without a tuner.
  7. i have heard this too but didnt know if it would work in this case. i do know i ran it home about 25 miles after the alt died and the battery was very weak and it was in the day time.
  8. my alt quit charging the other day on my 08 dodge. i replaced it and noticed the lighting bolt didnt go off when i started it up. also no charge. i got my smarty out and deleted the code. it works fine now. my question is would it ever cleared itself without the tuner deleting the codes. :banghead:
  9. thanks guys.
  10. hey guys, my name is tony from mighty diesel. if you need anything give me a call. thanks tony 877-354-7008:thumbup2:
  11. just go to my site. mightydiesel.com
  12. i have saw this after a good lift pump was put on a vp truck. i talked to a fass tech years ago and he said the vp head was wore. he had me to wire the fass so it would pump with key on but not while cranking. so i ran a wire to the electric window. someguys here puts a regulator on the fuel supply. i have saw pumps run several years like this. its worth a shot to find out.
  13. i have a pullrite slider also in my mega cab. works great.
  14. wonder why dodge dont put these on new. i been running a 3 micron afe fuel filter i sell. another note is these truck fuel tanks need a drain on the bottom. my farm tractor has a plug made right in the bottom i drain a couple times a year. they are always a little bit of water and trashy looking stuff.
