Marine
  1. So you mean to the v2 I guess?
  2. But I get turbo surge with the Mach 1.6 and the DDP95s I have. HTT said that my turbo is rated for 50hp more than stock and suggested no more than a 50 hp injector. I have my duration way down to 1200 now. Thoughts?
  3. With this info maybe I should try going back to the stock injectors and see the result is with the HTB3 (65 exhaust) I have.
  4. I will put a 1000 tune on when I get time. In the meantime I have a 2000 series but I did set the mins to 20 and 30 (I'm assuming 20 is the first min on the list and 30 is the 2nd min on the list in the Pulse), and moved the stretch to 1200.
  5. Thanks @Quadzilla Power. I think I am going to go to a smaller injector (75hp) and lower the pump stretch. I'm not sure how best to adjust the Pulse with my current setup; any suggestions? I generally run on the 2000 series tunes on level 1-5.
  6. Sorry, a part of your message is missing. Ship it to Quadzilla? Or I can upgrade my Adrenaline using the installer package? Where is that located? Either route I will still need the iQuad wireless module, correct? iQuad BT Module Thanks!
  7. Michael, I looked on their site but can't see a way to upgrade to the V2? Will it work with the Adrenaline screen or will I need to upgrade to a phone/tablet with BT? Thanks!
  8. Hi Gents. If I can hop in here with a question along the same topic. I have an HTB2 62/65/13ss with a Pulse Adrenaline and Mach 1.6 injectors. Essentially I want to lower my EGTs because I will be giving the truck to Dad and I want it more user friendly so he doesn't melt anything. If I move down to RV275 injectors (or even 60HP injectors) what will the result be? I called HTT and they suggested moving down in injector before I move down to an HX35. What are your thoughts? @Quadzilla Power maybe I can lower the EGTs by a lower injection pulse? Thanks!
  9. Marine changed their profile photo
  10. Hi. Do you have a pic of the connector and the pins? Thanks!
  11. It is exactly like that. At first it kind of irritated me because it wasn't working as it should, but I like it now.
  12. This is a great idea. The latch on mine does not lock any longer, so I have to have it strapped if I want to lift the console and use the middle seat.
  13. I replaced my blower motor about 4 yrs ago and all speeds except low work. I didn;t think about replacing the resistor to fix that. However, I like the lowest setting to be an actual off position.
  14. I don't have a draw straw, but when my light comes on I have 8-10 gallons in the tank.
  15. That is a good idea; I will check my fender wells too, as I know one is loose. Thanks for that tip!
