Code p0122 TPS
Have set a code 0122 but the truck is running fine. Researching the TPS and it is not very expensive. What is the difference between a TPS with a harness and one without a wiring harness? Both listed for a 2001 diesel. Now to replace it. I think it is behind the housing with the cables that control the throttle. What needs to be removed to get to it? Last question is should I dive in and replace it and how do I reset the trouble codes?
Ok if it needs changed, get a Timbos. I am convinced. Why do I get a code but truck runs fine. How do I erase code to see if it comes back again? If I do need a Timbos, what vendor do you recommend or is it sold direct.
Ordered an obd11 reader. Next morning, code was gone. Did I read somewhere that after 20 starts without the malfunction returning, the engine light and code will disappear? I really appreciate all your help. I retired from fleet maintenance in 1997 and all this drive by wire throws me. I am trying to keep up.
  • 5 weeks later...
