We are privately owned, with access to a professional Diesel Mechanic, who can provide additional support for Dodge Ram Cummins Diesel vehicles. Many detailed information is FREE and available to read. However, in order to interact directly with our Diesel Mechanic, Michael, by phone, via zoom, or as the web-based option, Subscription Plans are offered that will enable these and other features. Go to the Subscription Page and Select a desired plan. At any time you wish to cancel the Subscription, click Subscription Page, select the 'Cancel' button, and it will be canceled. For your convenience, all subscriptions are on auto-renewal.
- Replies 4
- Views 1.6k
Mopar1973Man 2 posts
MoparFreak1988 2 posts
Did This Forum Post Help You?
Ok so I know we have the hydro boost on our trucks so that is why I dont want to tempt fate on this one. As for my mystery when I was up north last week I saw single digit temps about 5 degrees f. I went and started my truck to move it out of the way, it started fine but I had no power steering and a growl from the pump so I shut it off checked the fluid to find it on the full line and smelling terribly burnt (I should let you know now that before I ever travel 200 plus miles from home for work I check all fluid for levels and abnormal smells... ect. it was fine when I left) I went back to the cab fired it up and I had power steering so I moved it and continued working thinking I would deal with it later on, well on the way back to my sleeping quarters I noticed a large pool of oil under the truck and yup its power steering and now I have none left so I borrowed my co workers truck went and got fluid in the morning and threw it in there worked for the day without problems and no leaks and when I left that evening untill I got on the highway I didnt have any power steering though I did have power brakes, when I got off all was fine and as it should be and as of this moment I have flushed the system and and all is good minus a minor growl under hard turns and my new fluid is degrading quickly (hence burning). Is my pump failing and where did the fluid come from it hasnt dripped a drop since, any help would be awesome and as always thanks again in advance.
