Fuel lubricity
Sorry if this is not the place to post this but I have found a chart with the latest fuel HFRR values with the addition of bio fuel.
Since most fuel stations will have between 2% and 5% biodiesel I thought this would be great info for us VP44 powered trucks.
I am having difficulty posting the chart if someone can help I will get it up asap.
Absolutely. I would love to add more to the site.
Just remember the Biodiesel is higher in cetane so it lower in BTU's so typically there is a small loss to MPG while using Biodiesel fuels.
Mike apparently 2%-20% only adds between .2 to 1.2 points in cetane values. That I don't have the chart for but I do remember the values. As far as BTU heat valve in 2%-5% biodiesel blends the BTU of heat only drops about about 2% if I remember correctly. It's a very small change.
