Electrical issues
Having electrical issues with my 2001 Dodge Ram 2500..going down the road the other night the lights behind my speedo went out. My cluster gauges I guess? I also noticed no marker lights and no running lights in the back..I heard a click and everything went dark any ideas? I checked most of my fuses and no luck
If you are sure there are no bad fuses, I would start looking at wiring?  Are you tapped into an power to run an accessory or mod?  Look for bad splices and connectors?  How about water in connectors?  Grounds? Chafed wires?  Get a multi meter and shoot wires for continuity.
I found a 20 amp fuse blown under the hood in my "15amp park lamp position"
I put another fuse in and it blew immediately dose this narrow down where the problem may lie?
I do appreciate the help guys
Pretty much narrows it down to the entire rig, all 4 corners marker lites to trailer plug to all dash lites. I would start with any add-ons and go from there.
