I am looking at a 2000 2500 4 WD w/gas motor.I have a 96 2500 CTD 2WD I would like to install the CTD into the 4WD truckMy questions areWould the gas 4X4 Trans bolt to the CTD?If not how hard are the CTD 4WD tran's to obtain usedBoth trucks are std cab 8'beds
I am looking at a 2000 2500 4 WD w/gas motor. I have a 96 2500 CTD 2WD I would like to install the CTD into the 4WD truck My questions are Would the gas 4X4 Trans bolt to the CTD? If not how hard are the CTD 4WD tran's to obtain used Both trucks are std cab 8'beds
is the trans auto or stick? you might be able to swap the output shaft and tail housing to make your trans ready for a transfer case
The Man you need to talk to is Chris Snyder He is on Many diesel forums as CSnyder he specializes in 2nd gen and 3rd gen Dodge rams, he does gas to diesel swaps and he buys and sells complete chassis or parts ect. His contact info for all your needs in both parts and advice in this department is http://www.ramboyz.com/
Oh yeah I've seen him around nice guy too! :thumbup2: (www.midwestdieselconnection.com) Here is profile page... CSnyder
Both Tran's are Automatic. I didn't know if the gas tran's would mount to the CTD being as the gas motor/trans was a 4wd. Ideally I would like to end up with a 4wd CTD truck
