What I have done:
1. #6 Fuel Plate - Full Forward
2. Boost Elbow
3. 4" Full Exhaust
4. TC Lockup Switch
5. BHAF
http://www.dieselpowermag.com/tech/dodge/1002dp_1994_to_1998_dodge_ram_power_recipes/1500_budget.html
What I'm thinking of doing (in order):
1. Timing
2. 3K RPM Springs
3. Injectors
I'm expecting my trans to blow up, so that will give me an excuse to go to a manual or build the 47rh. What I don't want to do is blow the head gasket, so I don't want so much power that requires me mod the head or valve springs.
What I have done: 1. #6 Fuel Plate - Full Forward 2. Boost Elbow 3. 4" Full Exhaust 4. TC Lockup Switch 5. BHAF http://www.dieselpowermag.com/tech/dodge/1002dp_1994_to_1998_dodge_ram_power_recipes/1500_budget.html What I'm thinking of doing (in order): 1. Timing 2. 3K RPM Springs 3. Injectors I'm expecting my trans to blow up, so that will give me an excuse to go to a manual or build the 47rh. What I don't want to do is blow the head gasket, so I don't want so much power that requires me mod the head or valve springs.
