Rear disc brake issue
angus
Working on the rear disc brakes today, time to replace pads, and I need to get the rotors off to be resurfaced. I have loosened the park brake cable disconnected the cable at the rear axle, and I can`t get the rotor to budge!
I have tried everything short of getting a bigger hammer and the rotor will not release from the axle flange??? Am I missing something here, or do I need a bigger hammer? I don`t want to destroy the brake rotor.
OK, issue solved. For anyone removing their rear disc, Get a block of wood and as big a hammer as you can swing.   Violence is necessary!
No need to loosen or disconnect park brake cable either
Edited by angus
Check the hub for clips on the studs holding the rotor in place. You might have to get behind and back off the parking brake shoes turn the star wheel towards the axle is loosen away from the axle is tightening. Last possible is nature's thread locker. You might have to spray the hub with PB blaster and smack the rotor with a rubber hammer to see about getting it to move.
